Got my 8.8 Housing Finished Today
Can you recap on the way the car launches with the mini bars? Mine seems to launch like an old mopar now the entire car lifts evenly but the rear feels like it is being pushed foward HARD!
lol, a friend of mine just compared it to a old mopar, the only "problem is if for some reason i forget to power shift it unloads the tires
I've never had an old mopar lol. Although I do have the G-force 4 link setup and a 8.8 that needs fabbed. Just wondering if the "mopar" feel is a good or bad thing?
Its definately not a bad thing, you do not want your suspension to waste energy and this way utilizes all of the energy. The absolute LAST thing you want your suspension to do out back is to squat! This set up launches the car foward from the start....
After owning F-bodies for the last 20+ years it no longer feels like an f-body launching. corners feel the same though
Now all i have to do is get my axles and weld up the housing I just hope i did not slow my poor bolt on Lt1 down too much by installing 3.73s instead of going back with the 4.10s
I know it will be much different launching at 5k rather than 3k and praying the 10 bolt will stay together
Looks good! Any chance you'd share your price list on the build? I am thinking about keeping the mustang brakes and using the 8.8 in its narrow state. I am looking into this as my locker is not holding at times. Still torn between t/a, your set up, or mini four linking it to the uni-body though.
btw,I like to see it in person. What track do you frequent?
The spring saddles and associated brackets should be marked from axle to axle to get them into the same position.
The process is not difficult at all,measure as many times as you feel you need then make your cuts.
#34
We put the 7.5 at 0 and measured where the flat part of the bump stops are, I think a zero the were at -5
So basically set the pinion angle at 0* and the flat spots for the bump stops where around -5* when you welded the axle tubes to the 8.8 housing.?.?
#35
This is more what I was looking for. I know you adjust pinion angle with the rear in the car. My question was more towards the spring perch angle in correlation with the pinion angle when sitting it up to be welded.
#36
#38
#39
Looks good. I can't wait to do an 8.8 build on mine. I've got a couple different 8.8 rears I'm looking at locally. One's a Fox body rear with 4.10's, and the guy only wants $100 for it. So, I figured what the hell. Just need to find a time to go get it. I already know a guy with a junk 10-bolt that I can steal the axle tubes off of anyways. So, I figure I should be able to do this pretty darn cheap.
