auburn diff
Old Apr 27, 2010 | 03:45 PM
southpaw0314's Avatar
Default auburn diff
right now i have 2.73 with a torsen in my rearend and i found one somewhat close to me with 3.73 and has a auburn in it. how do the auburns compare to the torsens? he says it is a new differential that was installed less then 2000 miles ago so it shouldnt be wore out or need new clutches. Has anyone had problems with a auburn?
Old Apr 27, 2010 | 04:09 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Torsens typically last until something catastrophic or as in the following thread link
https://ls1tech.com/forums/gears-axl...tle-rough.html
Auburns' cone clutches wear out over time,breakage is typically limited to the Auburns spider gears.
Old Apr 27, 2010 | 06:08 PM
bump.
Old Apr 27, 2010 | 08:31 PM
bump.
Old Apr 28, 2010 | 06:53 AM
WizardofDetailing's Avatar
Well I have 4.10's w/ a new auburn posi and I have had no problems what so ever. It's definately better than whatever was in my stock rearend.
Old Apr 28, 2010 | 07:37 AM
Removed my Auburn at 118,000 miles,it looked like it had about maybe 10,000 miles left before the cone clutches would have been worn to non-usability.
Didn't remove it because of a problem,entire rearend replaced with a rearend I built with Richmond 'used' 4.56s' and an Eaton posi I picked up at Summit.
