klunking
Old Jun 9, 2010 | 04:24 AM
Reno's2fastestfbodys's Avatar
Default klunking
well had my auto trans built about 9 mo ago. it always shifted kinda hard before and learched into driving gear. within the last week or so my car now makes a clunking noise coming from rear. also when coming down from speed as it goes down through gears..... any thoughts? advice? gas and a book of matches?lol
Old Jun 9, 2010 | 01:10 PM
The Fugitive's Avatar
okay 1st you are going to have to get it up into the air to find out where the noise is coming from. Gonna have to narrow it down because it's obviously with the driveline. Do you know where you feel the clunking at or where do you think you hear it? This is what a broken pinion sounds like
Old Jun 10, 2010 | 06:06 AM
torque arm bushing!
Old Jun 11, 2010 | 06:06 PM
drago1217's Avatar
I am having the same prob in my m6. Same thing loud clunk when I shift and when I let off the gas to decelerate. It sounds like the rear end is falling apart. But with acceleration no noise. What gives. On my way right now to get a gasket to look inside the rearend.
Old Jun 11, 2010 | 09:42 PM
drago1217's Avatar
Well I figured mine out. About a month ago I replaced my pinion seal. when I tightened my pinion nut I did not tighten it enough and it backed out on me leaving the yolk and the gear attatched to it loose. When accelerating the way the teeth of the gears are designed pushed that part snug but without pressure on (when letting off the gas or shifting) the teeth from the gear that the yolk goes on were eating up the other one. Sorry don't know the names just know what it looks like lol.
Old Jun 16, 2010 | 05:38 AM
sounds like fun! all i had was a torque arm bushing go bad and did a casper fan switch with manual over ride at the same time. pleased with the outcome of that day.
Old Jun 16, 2010 | 06:27 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You're more than likely in for a rear end rebuild at this point. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jun 16, 2010 | 09:04 AM
drago1217's Avatar
Yeah I know, I can't afford one right now. I looked at the teeth on the pinion gear, they have a little wear. Thankfully I caught it in time. Now that I tightened it up it works fine but I think I need a new pinion nut. Someone told me it is supposed to be a lock nut and mine isn't tight. I also heard I should put around 450 ft/lbs on it so I think ill get a new nut and put some more *** into it. But it works for now. I've already priced a moser 9" and will start saving lol.
Old Jun 17, 2010 | 12:30 AM
02CamaroSSLE's Avatar
how do you plan on puttin 450 ft/lbs???
Old Jun 17, 2010 | 06:16 AM
drago1217's Avatar
**** I don't know I will probably just grab a bar and tighten the crap out of it LOL
Old Jun 17, 2010 | 08:14 AM
Carter Hays's Avatar
You use a companion flange holder. The proper way is to install a new crush sleeve set preload etc...
Old Jun 19, 2010 | 12:00 AM
me6894's Avatar
The proper way is to measure the rotating force it takes to turn the pinion with the carrier assembly out of the car. There is a spec in the service manual for this.
Old Jun 19, 2010 | 04:31 PM
Outlaw72's Avatar
I set mine at 25 inch lbs
