8.5" 10 bolt how strong?
My Tahoe has a 10 bolt rearend with a Auburn Pro differential and GM performance gears.It's managed to survive my 449/515 hp/tq supercharged engine,but now I've switched to a 4L80E transmission and want a go with a 4.56 gear,will the 10 bolt take the abuse?
There are Impala SS running LOW 10's, in the 10.0x range that are pushing 800+hp thru built 8.5's. What usually gives up is the crappy Auburn posi. Most of the fast Impala guys are running Eatons. To answer your question directly, the most likely failure if you have one will be to lose limited slip and be a peg leg, if you upgrade the carrier to an Eaton, that will help immensely.
You can view the fastest (that will post timeslips) at:
http://dan.esteban.com/impalass/ReturnTopET.asp
Kelly Rosato
Kelly Rosato
Originally Posted by blacktransam
can one of these be put into my t/a?
The F-body rear has a 4.75 x 7 bolt pattern, The B/D body rear is 5 x 5.
Most B body rears are disc brake, but are only set up for 3 channel ABS. So if you don't have traction control it should work ok. I haven't found out yet how many teeth the F-body uses.
However, the D-body has 4 channel ABS compatibility, but is a drum brake rear only.
And you'd have to have the F-body brackets welded to the B/D rear since the B/D uses Upper/Lower control arms and the F uses Lower control arms and a panhard bar.
So it can be done with a bit of planning and not cost anywhere near as much as putting in a 12bolt or a 9". And the strength difference between the 12 bolt and a 10.5" Ten bolt is minor. The 12 bolt is a 8.75" ring, the 10 bolt is 8.5".
Hope that helps!
i'm gunna have to work on this idea and do a bit more research
pros
1. these have the same bolt pattern as all f-bodys do.
2. i found out that the LS1 brake mounting plates will bolt right up.
3. these cars were leaf sprung in the rear so there is only two brackets to cut of. the impala axles center section has built in mounting brakcets that cant be removed.
4. there is hundreds of camaros and f-bodys in junk yards and the entire 8.5 can be bought for $200 or so.
5. they are almost just as strong as 12 bolts. i have ran one behind my 700rwhp 69 camaro for 6 years and never broken anything in it.
6. every aftermarket rear axle company supports them and you can find everything to make them stronger for cheap.
cons
1. it is a bit shorter then 4th gens since they dont use as much wheel backspacing. you can just use spacers or get a different backspacing in the rims.
2. no torque arm mount. this is ofcoarse the biggest most important problem there is. with some good welding skills this can be fixed.
3. you will also need to weld lower control arms and a pan hard mount.
I have though alot about this progect. the thing is that i already have a strong 8.5 with 4.10s that can out of my old 1980 Z28. when i bought my 69 camaro the first thing i broke was the orignal 8.2 that was in it. then i just cut the leaf spring pearches off my 8.5 and welded them to fit the 69s leaf springs. i ran this for years and never broke it so i am a beliver. now it is time to try to fit it in the 02 to keep the tradition hehe.
Originally Posted by JimsZR2
The rear axle found in the 94-03 ZR2 p-up's and Blazer's are 8.5in 10-bolts. They also are the correct bolt pattern, have disc brakes, ABS, and a gov-loc.
this interests me more than n e thing i have heard so far. I think it's time to go junkyard shopping and get maybe 2 of them. One to practice on and one to use.
here is a thread i started a while back of the idea of just removeing the torque arm and useing latter bars to make the swap easyier. check it out
https://ls1tech.com/forums/drag-racing-tech/122483-why-not-get-rid-torque-arm-better-60s.html
Originally Posted by 99power
Hi! Guys just to let you'll know the 80's Buick GN came with a 8.5 also.
but neet to ck the axle flange,may be different ![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
[QUOTE=taqwache]yup they sure did but they also have the same problem with the built in upper conrtol arm mounts. also these are very, very rare for 2 reasons. 1. because of how rare turbo buicks are already and 2. because people that usually have hot rodded monte carlos, regals, cutlasses, and other g-bodys usually ****** up all the avalibale ones as a bolt in replacement for the factory 7.5. i think it sucks how GM acually put these behind a turbo V6 car that usually does not have that much low end torque but would not put it behind a LS1/LT1 car that has tons of axle breaking low end torque. go figure.[/QUOTE
Yes I use to be one of those,'79 chev malibu with Lt1
Hi 13's with a cam,(what the guy I got the engine told me) intake,headers,true dual with vforce mufflers and strip inside plus those car weight around 500 lb less than the 93-on camaros.sorry sold the car(wife said to much money to finish it)So here I'm building a 99 Silverado.(wife doesn't mind) go figure.
