Drive line Vvvvvvibrrratttttion. Exhausting my options
Old 03-14-2011, 08:31 PM
  #81
CamaroZ28_LS1's Avatar
Found my issue of the sway bar causing the vibration, fixed.
Old 04-02-2011, 10:36 PM
  #82
STEEPSS's Avatar
Well, I think I found out what my vibration is today.
The driveshaft is out of round. .030 to be exact. SO I guess I'll be ordering one of those.
Old 04-04-2011, 05:51 AM
  #83
Driveshaft Shop's Avatar
We have found the stock steel shaft have a harmonic set up from the shaft to the torque arm, you might want to consider a Aluminum shaft if you want to make sure its not going to have a vibration.
just my .02
Old 04-04-2011, 10:04 AM
  #84
STEEPSS's Avatar
just my .02
Shaft is chrome moly. Thanks though.
Maybe quote me on a price for a stock length, 1350 U-joint shaft that will take some serious abuse? 600whp 6 speed?
Old 04-04-2011, 10:25 AM
  #85
To make a 3-1/2 1350 Aluminum shaft with
with a forged yoke it would be about 450.00
or with a Billet Strange yoke 500.00
Old 04-04-2011, 02:15 PM
  #86
STEEPSS's Avatar
****. i took the CM driveshaft out for measurements, just for kicks put in my stocker aluminium, and it still vibrates!!! the stocker never did before. Pinion angle is at 0*,
Maybe tailshaft bushing?
Old 04-04-2011, 03:23 PM
  #87
this may be the problem, you need to have equal angle at each. what happens is the top u-joint is moving back and forth and the bottom is not. they need to cancel each other out
Old 04-04-2011, 03:37 PM
  #88
STEEPSS's Avatar
So, to remedy this, I'd need to move my transmission mount down possibly? Like with washers?
That is one thing I haven't tried yet.
Old 04-05-2011, 12:59 AM
  #89
studderin's Avatar
Originally Posted by studderin
if you have a poly trans mount, and a aftermarket trans Xmember you can get a vibration form the front u joint not being happy. take out theat poly "preload spacer" under the mount, see what thats dose. You might even have to space down the trans Xmember to adjust for the rear end being lowerd. 1 or 2 good washer between the Xmember and the body can make a big difference.
ya.....
Old 04-05-2011, 01:06 AM
  #90
an aluminum DS from Brute speed is $430 and the chromemolly is $450.
Old 04-05-2011, 05:25 AM
  #91
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Thumbs up
Thanks! I sell the 3.5" PST 1000 HP aluminum driveshaft with a forged yoke for $430.00 shipped. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 04-05-2011, 04:05 PM
  #92
studderin's Avatar
whats the weight on one of thouse bob? I just bought a moser billey yoke with the bolt on caps, for my steel DS, and looking to get somthing lighter.
Old 04-05-2011, 04:41 PM
  #93
don't just try things with out making the measurements, if you measure the 3 angles and either post them or call me ill tell you what to move and how far.
i believe the pinion angle is the issue (should not be Zero)
Old 04-05-2011, 07:44 PM
  #94
STEEPSS's Avatar
The pinion angle was only taken to 0* to determine if the driveshaft, or something else was the issue. I know it shouldn't be 0* more like -1 to -2*. When it's at -2*, the vibration is worse. I'll try to get to the shop and take some measurements (angles) tonight
Old 04-05-2011, 08:13 PM
  #95
STEEPSS's Avatar
ya.....
Rubber mount and stock x-member though John. The truth is in the angles.........
Old 04-06-2011, 01:27 PM
  #96
STEEPSS's Avatar
Well I took some careful measurements just now. Car was level, suspension loaded.
I set the pinion angle to -1.5*, off the Pinion yoke
pinion yoke= -1.5*
Driveshaft= 0*
slip yoke = -1.5*
I'm truly at a loss now. Does anyone know what the tolerance for play (vertical) in the slip yoke is supposed to be?
Old 04-06-2011, 04:06 PM
  #97
pinion yoke= -1.5*
Driveshaft= 0*
slip yoke = -1.5*
The yoke will have a little play up and down, its bushing so when it gets hot it gets tighter as the parts heat up. your setting are text book correct. i would have to say at this point check the balance on the shaft.
Old 05-10-2011, 10:25 PM
  #98
STEEPSS's Avatar
I finally have an update.
After FIVE WEEKS of waiting, I got my PST aluminum driveshaft (nice piece but not worth the wait)
I install it, go drive it, no vibe at 50, none at 60, (grins) so i put my foot in it, and right about 90 mph it takes off and vibrates like a *****. About the only part of the equation that hasn't been checked thoroughly is the tailshaft (output shaft) bushing. I'm wondering if all that vibration that i was experiencing could have wallowed it out? Also, is it a huge PITA to do this repair in the car? I've only ever done it on a bench.
Old 05-11-2011, 06:36 AM
  #99
LS1Tech Sponsor
Question
Have you checked to see if you have a lot of play at the tailshaft bushing? Bob
__________________
Old 05-11-2011, 07:41 AM
  #100
If its good up until the MPH your asying i would look into other things, if a shaft it out of balance it will normally come on slowly and peak. it sounds like the vibration comes on strong in a certain situation. if its the bushing torque will change the severity of the vibration (playing with the gas pedal will make better or worse)
<B>
Quick Reply: Drive line Vvvvvvibrrratttttion. Exhausting my options
