Moser 9" seems like worn out ring and pinion
Just bought the car, rear end sounded fine but started making little clunks when shifting lightly. I've heard of this problem with these ford 9" but I put the car on a lift and saw the driveshaft would move 1-2". The pinion takes that long to hit the ring. I took a video of it on my phone. When I mean it moves I mean by turning the driveshaft. I'm just wondering what the problem could be before I take the differential apart? Thanks for your help
In this video it was in gear with the wheels off the ground, at first it barely turns then feels like it slips and starts turning an inch or more.
http://s256.photobucket.com/albums/h...1287977615.mp4
LS1Tech Sponsor
Your 9" may have a locker in it, in which case the movement you are seeing is normal. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Also it does have a whine but it is barely noticeable from 30-70.
Is the fluid suppose to be all the way up to the bottom of the hole on the back of the rear? It seems very high and looks like it would take a gallon to fill up.
LS1Tech Sponsor
A little whine isn't bad.
The oil fill is located on the left side of the housing on the Moser 9 inch rear end. It is relatively close to the torque arm bracket. Fill the rear up until the fluid starts to seep back out of the fill hole. It should only take a little over three quarts of gear lube. Bob
__________________
LS1Tech Sponsor
Napa 80/90 weight non synthetic gear lube is what I use, and you fill it up until it is to the bottom of the hole. Bob
__________________
