Carbon DS ?
Old Nov 26, 2010 | 08:07 AM
HioSSilver's Avatar
Default Carbon DS ?
Pro's and con's.....where did you get it? How much less does it weigh that the stock aluminum? I have a m6.
Old Nov 27, 2010 | 06:08 PM
Supers's Avatar
Restricted User
Very close in weight, but stronger then the aam shaft, as is the aftermarket Al shafts
Old Nov 27, 2010 | 10:48 PM
Flielow's Avatar
I got the acpt carbon fiber, I got it from a member here. I got 700 to the wheels, I think they're good for 1000 HP
Old Nov 28, 2010 | 06:56 AM
HioSSilver's Avatar
does it work with the 10bolt?
Old Nov 29, 2010 | 04:13 PM
Supers's Avatar
Restricted User
Al is good for 1000hp to, but any will work with any diff
Old Nov 29, 2010 | 06:29 PM
Latch's Avatar
Why would you spend the money on a driveshaft that's good for 1000 HP and keep the 10 bolt behind it??
Old Nov 29, 2010 | 07:32 PM
HioSSilver's Avatar
Weight....the less weight that 10 bolt has to move the longer it will last. I've been a 11.1 on the 10bolt with a m6. I want to eventally get a 9" but it's $4000 for the one I want. I want it as lite as it can be made. So far I have broke 2 set's of 4.10's. Now I have 3.90's and they look stronger so hopefully they last longer.
Old Nov 29, 2010 | 08:49 PM
Mike Morris's Avatar
I have the acpt too and love it!!! Much smoother too. Like Hio I am going for light weight to help my ten bolt live a while. I have about 100 passes on my ten bolt and this drive shaft foot with 1.6 sixtys and its hasn't missed a beat.
Old Nov 29, 2010 | 09:40 PM
HioSSilver's Avatar
where did you get yours? How much weight did it save?
Old Nov 30, 2010 | 11:24 AM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
I put a PST Carbon shaft in my personal car and saved around 9 pounds from the Chrome-moly one I had in it using the same yoke.
HioSSilver keep in mind the drive shaft from a 10 bolt to a 9 inch will be different.
Old Nov 30, 2010 | 12:41 PM
Got it from a member on here. Saved maybe 2-3 pounds??? But remember thats recipicating weight and its stronger. Got the heavy duty yokes which may have added weight. I even added the aftermarket panhard rod to save a little more. My car is light and anything sans of gutting it,I try to lose some weight here and there.
Old Nov 30, 2010 | 11:00 PM
69TA's Avatar
ACPT checking in.
pros:
light weight
stronger
less vibration
con:
Old Dec 1, 2010 | 07:45 AM
HioSSilver's Avatar
Cool ...I need one for a 10bolt m6. I hate to get one for the 10bolt....but I think it might live for a while with these 3.90's in it. I'm tryin to do what I can to get a crate ls6 to go 10's and be a a DD still, so all weight has to go but creature comforts has to stay.
Old Dec 1, 2010 | 09:07 AM
69TA's Avatar
best part is you also don't need a driveshaft loop or ever worry about your ds breaking and flipping the car over.
Old Dec 1, 2010 | 11:30 AM
94transbird's Avatar
Exactly how much is a Carbon DS?
