Finished my Moser 9" Build up!!!
Here are the specs!
PST Aluminum Drive shaft rated at 1000hp
Moser Ford 9" F-Body 98-02 housing
Moser 31 spline axles
Trac-Loc Diff
Moser Nodular Iron Center Support
Moser Chrome Molly Yoke
Moser LCA relocation Brackets
Moser Front Pinion Support
Moser 4 Channel ABS option
3.75 Pro Street Gears
Moser Drain Plug
12mm Standard Length Studs (ARP studs if I recall)
I am thinking sunday I will install it.![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Before:
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300788.jpg)
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300789.jpg)
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300790.jpg)
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300791.jpg)
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300792.jpg)
AFTER:
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300793.jpg)
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300794.jpg)
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300795.jpg)
Trac-Loc Diff
Moser Drain Plug
Before:
AFTER:
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300796.jpg)
LS1Tech Sponsor
Looks good! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
LS1Tech Sponsor
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Thanks, I appreciate it! Bob
__________________
So drove to my friends house to use a grease gun to hit my poly sway bar mounts. Found the source of the vibration at 2000 rpms. The stock tunnel brace was right up against the exhaust on the 3" diameter of the intermediate piping. Took a pry bar and pulled it off the exhaust and bam no more vibration. Car runs really smooth. Can't wait to get my UMI Adj. Torque arm and tunnel brace mount! Launching the car with a full rear suspension set up should be successful!
Here's a few more pics of the install. I don't have a pic yet of it installed.
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300798.jpg)
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300800.jpg)
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300799.jpg)
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300803.jpg)
![](http://i83.photobucket.com/albums/j318/CamaroZ28_LS1/Moser%209%20inch/S7300801.jpg)
LS1Tech Sponsor
Good deal, also make sure the torque arm bracket doesn't hit the floors sheetmetal. Bob
__________________
Doesn't seem to, going over some bumps are a little noisy (sounds like the bump stop) but not as bad as my 10 bolt. The 10 bolt would rattle bad over bumps... Leads me to think it was the stock sway bar end links(replaced with Poly) and I made my rear shocks stiffer to reduce and jouncing.
