TruTrac Axle Endplay
Just rebuilt the entire rear end of my car a couple months ago, its a factory 7.5" 10 bolt. The original Auburn diff exploded so I replaced everything.
New parts included Motive 3.42 gears, Detroit TrueTrac diff, Moser axles, new c-clips, all new Timken bearings, and new seals.
The problem is there is excessive endplay in the axles, meaning there is too much clearance between the inner end of the axle shaft and the "spacer" inside the diff. So every time I come around a turn hard, the axles slide inward or outward, and often cause pad knockback.
Anyone else running a TrueTrac diff and having this problem??![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
The only solution I can think of is to have a machine shop make a new spacer that is wider so it takes up the play between the two axles.
However, after reading some threads from thirdgen.org on the same issue, it appears the Moser axles may have c-clip grooves that are wider than stock, which would cause the issue.
The solution one guy came up with was to use external snap rings to take up the space between the c-clip and it's groove. He placed the snap rings in the outer most part of the c-clip groove and then placed the c-clip on the inner side near the side gear. This effectively took up the slack and tighened up the endplay to a very acceptable .005". The snap rings are made of "spring steel" and are apparently quite strong, he reported no issues after extensive testing with the snap ring setup.
