Gears???
Old Mar 22, 2011 | 09:13 AM
ParkerSS's Avatar
Default Gears???
Wondering if I need new gears to get the most out of my set up.
Car is a 2000 Camaro A4 w/ mods in sig makes around 435-450rwhp and is still running with the stock 3.23s.
Would 3.73s be good? Or 3.42s?
Car is mostly street but goes to the track now and then and some road courses.
It's a beast from a dig but kinda lazy at a roll and cruising at low speeds is at about 1500RPM. Like just putting through a parking lot.
Thanks everyone!
Old Mar 22, 2011 | 10:46 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
3.23s' to 3.42s' will increase the torque to the carrier/axles/wheels/tires by 6%,something you'd feel but is it justified by a swap into your existing rear,considering time,parts & setup,probably not,would be easier and less expensive to just pick up a 'take-out' complete 3.42 rearend to swap in if your thinking 3.42s'.
3.23s' to 3.73s' will increase torque by 15% and would probably be the recommended change by most.
Pick up a 3.42 rear,install,and put 3.73s in the orig. rear,then install that and have the other for a 'backup'. This would allow the least amount of 'downtime',plus you'd be able to experience both and pick which suits your needs.
Either one will make your convertor feel 'tighter' and make the car more 'responsive'.
Old Mar 22, 2011 | 11:02 AM
justin hover's Avatar
3:42s would be the biggest waste of money you've ever spent...you wouldn't even notice a difference...3:73s would be the way to go for sure...
I see you have a 3000 stall though.. 3:23s are a perfect gear for a stall...you should get a higher stall ...you'll get way more performance out of a higher stall...
I jumped from 2:73s to 3:73s...that was def. worth it.....3:23 to 3:73s you won't notice much...alotta money for a slight increase in accelaration...I would get a 3600-3800 stall if I were in your shoes...
Old Mar 22, 2011 | 11:25 AM
ParkerSS's Avatar
I DD the car a lot so I dont want to go to a higher stall really...
Old Mar 22, 2011 | 11:47 AM
A 3500 w/3.73s wouldn't probably feel any different(looseness) than 3000 w/3.23s'.
Old Mar 22, 2011 | 01:33 PM
Tyler Z28's Avatar
3.73's all the way.
Old Mar 22, 2011 | 02:16 PM
ParkerSS's Avatar
So 3.73s would still give me more acceleration w/ my 3000 right?
Old Mar 22, 2011 | 02:23 PM
Tyler Z28's Avatar
correct.
Old Mar 22, 2011 | 02:25 PM
LS1T56FTW's Avatar
Yeah. Your next mod should be a 4000 stall, seriously.
Old Mar 22, 2011 | 02:27 PM
LaBLKv6Z's Avatar
4.10's would give you even more hehe, nah but out of your options, 3.73's would be worth the time invested.
Old Mar 22, 2011 | 03:02 PM
ParkerSS's Avatar
Street driving as much as I do and road racing quite a lot I really don't want a bigger stall I just don't. Thats why I was asking about gears. I JUST had that stall installed and it wasn't cheap...
Old Mar 22, 2011 | 03:44 PM
A higher stall would give you more performance hands down over gears.....
The slight jump in gears will help you pull better down low, second gear is a monster, but not much since your coming from 3:23s...If you have the money do it, you'll enjoy it no matter what...sounds like you kinda had your mind made up..you'll enjoy them
