Auburn Gear Oil change questions...
So I have a 98 TA stock 10 bolt rear and have never changed the gear oil. I have read that all 98's have Auburn rear ends (is this true?) and that I have to use 2 qts. of gear oil with a limited slip additive. I picked up 2 qts of Valvoline Durablend Synthetic 80w90 that has "limited slip" written on the bottle and says it is good for GL-5. Does this mean it already has the limited slip additive in it? Is this all I need or do I still need to get this additive? Also, the only way to drain the old oil is by pulling the cover off, right?
Cover has to be loosened to drain the fluid,but it's best to remove it to do a visual inspection. Your cover magnet will appear covered with metal shards,normal because of the way the magnet is holding all the iron 'dust'.
Yes,98s' and earlier got Auburns.
How many miles on it ?
I can't answer your oil question as I always use non-synthetic gear oil. I only use the additive when an Eaton posi is involved,not that that's what I'm recommending to do.
125,000 is a good life for an Auburn. I've seen the Auburns' cone clutches wore completely out at a range of 110,000 to 150,000.
Thanks for the responses. Anybody else running something different? Will this Valvoline synthetic "limited slip" be good or should I just get non synthetic with the additive?
Okay good thing I didnt even put it in yet. What if I got 2 qts of this: http://www.summitracing.com/parts/LUC-10043-1/
Its non synthetic and has the additive in it
