2.73 to 3.42 gains
![ReadPB](https://ls1tech.com/forums/images/smilies2/readPB.gif)
Oh, moving the battery... weight distribution. Made traction a little better.
And OP, I agree... get a used set. Got my gears and diff for free, but from two different people.
So there is absolutely no gain going from 2.73's to 3.42's as far as 1/4mile times go? Will the car dyno more, putting more HP to the wheels?
How much does it hurt your fuel economy?
I've got the 2.73's now and I get 27MPG highway at 70MPH. Although, with 2.73's my car doesn't feel as peppy off the line, and it's kind of hard to spin the tires, maybe I just have really good tires? Lol
It didn't really improve my driveability that much actually. but then I live in an area where there isn't a whole lot of hills to drive up either.
Would I swap out my 2.73's for 3.42's again?
Probably not.
I think I would actually opt for a bigger stall then my 3600 to be honest, and keep the stronger gearset.
If you don't care about the mileage much, just opt for 3.73s. Make it a change you really notice.
I too had a 10 bolt that I got with 3.73s that broke.
At the time I needed a new rear fast and all I could find was a 2.73 rear so I picked it up. from a roll I can't tell the difference. Taking off from a stop I do notice it takes a bit more RPM to get going.
Lately I've been thinking about getting 3.73s put back in but after some reading the $6-700 that I'd have to spend for new 3.73 gears and labor to get them isn't worth the .1-.2 and the slightly better driveability. I'll get steeper gears when I get a good rear in the car.
Lemons is spot on
Lemons is spot on
Lemons is spot on
Lemons is spot on
From a roll I think 2.73's should be better, since they'll be in a lower gear. Off the line in my car, it's tough to spin the tires actually.
My car has the 2.73's, and I know if I put my foot down when the car is ever over 85MPH I might as well forget about it, I'm not going anywhere fast. I'll actually lower my speed to 84MPH before getting into it again, because the car will still jump into it at that speed. It's even weaker than the 40MPH deadspot.
