cheapest fab 9in
Old May 28, 2011 | 05:01 PM
pkriner's Avatar
Default cheapest fab 9in
who sells the cheapest fab 9in housing only???
Old May 28, 2011 | 06:28 PM
TransWS6Am's Avatar
What good is a fab housing without the torque arm for the fab housing? What I'm saying is, what do you plan to do for a torque arm? The torque arms on fab housings are made for the housing, you just can't bolt any torque arm to it. $1250 shipped for a badass housing and torque arm package. You won't find a cheaper fabed housing, https://ls1tech.com/forums/drag-raci...y-housing.html I just installed mine last weekend, I got a complete rear end/long torque arm/watts link/and drive shaft package.
Old May 28, 2011 | 07:02 PM
Zmg00camaross's Avatar
^^^ what he said end thread I own a fully MWC rear suspension and are great pieces at a great price.
Old May 29, 2011 | 08:36 AM
infamoustransam's Avatar
i also have the same mwc rear. even if it isnt the cheapest its definetly built the best ive seen.
Old May 29, 2011 | 02:23 PM
pkriner's Avatar
thanks guys ima go with the mwc fab for sure does anyone know the weight difference on the fab vs regular 9in?
Old May 29, 2011 | 02:24 PM
pkriner's Avatar
oh and also will my factory driveshift work?
Old May 29, 2011 | 03:24 PM
TransWS6Am's Avatar
The stock drive shaft will work, but it will be 1/2" short so you may get vibrations. On top of that, if you are making enough power for a 9" you better upgrade to a driveshaft that will handle the power, my factory drive shaft broke way before my rear end did.
I was doing about 90mph on a highway pull and BOOOM! it twisted in half, right in the center of the drive shaft, I didn't have a safety loop but it wouldn't have made much of a difference on account of the drive shaft twisting in half right in the middle. That broken drive shaft cost alot of money. It destroyed my adjustable torque arm, y-pipe, and cracked my transmission tail housing, and put some nice holes in my floor board. So well over $1100 to repair by the time i bought a upgraded drive shaft and replaced all the broken parts my stock drive shaft took out. Oh and the $300 tow bill.
It could have been alot worse for me, it could have came through the floor board and took me out, or caught the pavement just right and flipped the car.
What im getting at is if your upgrading to a 9" than its a no brainer to upgrade the drive shaft. **** im on my 3rd drive shaft now, My stocker, then a stock length chromoly sphon, and now a PST 3" thats the correct length for my MWC 9".
Being cheap now may cost you alot later, maybe even hurt yourself or someone else, broken drive shafts are nothing to play around with, like i said my stock drive shaft broke before my stock rear end did.
Old May 29, 2011 | 03:28 PM
TransWS6Am's Avatar
I'm not sure on the housing it's self, but a fully assembled MWC 9" with aluminium center section weighs the same or lighter than a stock 10 bolt I do believe.
Old May 31, 2011 | 01:11 PM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
These guys have pretty much nailed it on the head. if you have any more questions let me know.
Old May 31, 2011 | 09:04 PM
brad3579's Avatar
I have the same rear end on order right now, how do you like the watts link
Old May 31, 2011 | 09:15 PM
TransWS6Am's Avatar
The watts link seems great so far! It bolted in real nice, and adjustment is a breeze. In all honesty I hadn't drove the car since August, so I can't remember what the ride felt like 9 months ago. I mostly got the WATTS to run true duals over the axle, which is ironic, cuz the car is down again on account of exhaust clearance issues, I'm trying to decide if i should go with the Kooks true duals or order the mandrel bends and do my own.
It seems like i'd be the first with a MWC 9" and kooks true dual combo, so I can't find any info if there will be clearance issues, I might just bite the bullet and be the genie pig.
Old Jun 1, 2011 | 11:40 AM
westtexasbuff's Avatar
I bought my bare Moser Fab9 from Bob @ Brute Speed for $800 shipped. Got it about 4 days after ordering. Painted it myself to save on powdercoating cost. I like to have things when I buy them, so I couldn't wait months to have a rear. The housing by itself weighs 74lbs.
Old Jun 1, 2011 | 05:15 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thanks, I appreciate the order! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jun 1, 2011 | 05:20 PM
Got a PM asking what our housing weighs so I figured I would post it up.
Our fabricated f-body rearend housing in stock width with a back brace installed, powder coated, and all the bolts that we supply is 62.2 pounds. Even includes sway bar mounts, drain plug, e-brake cable brackets, caliper brake hose mounts, and chassis brake hose mount.
