Solid Pinion Spacer
Old Jun 21, 2011 | 12:39 PM
Midnight00SS's Avatar
Default Solid Pinion Spacer
Wut does this actually do or help in the rear?
Old Jun 21, 2011 | 02:10 PM
SSCamaro99_3's Avatar
Keeps the pinion depth more constant, and helps with keeping the pinion from walking up the ring gear, as I understand it.
Old Jun 21, 2011 | 02:30 PM
SS SLP2's Avatar
^^^^ k-rect
Johnny
Old Jun 21, 2011 | 10:35 PM
Originally Posted by SS SLP2
^^^^ k-rect
Johnny
gotcha, does it help out alot?
Old Jun 21, 2011 | 10:55 PM
01ssreda4's Avatar
^^^^ k-rect
Johnny
Due wut??
Old Jun 21, 2011 | 11:26 PM
Originally Posted by 01ssreda4
Due wut??
huh lol?
Old Jun 21, 2011 | 11:32 PM
SS SLP2's Avatar
Solid Pinion Spacer does as SSCamaro99_3 stated, it will mantain constant ring and pinion settings
where as a crush sleeve may/will crush more after a/several hard hits allowing setting to change
I like to "do- er rite"
Johnny
Old Jun 22, 2011 | 11:33 AM
It makes setting up the gears a bit more time consuming, but for about $20, why not do it while you are in there.
Old Jun 22, 2011 | 11:59 AM
$750 L98's Avatar
How odd, I was contemplating just this. Damn crush sleeve on my spare 10 bolt rear is letting the pinion walk all over the place. So the consensus is there is no reason not to use a solid sleeve? I will be ordering one in that case!
Old Jun 22, 2011 | 12:53 PM
Yea sounds like a good idea then
