Are these the correct parts for replacing the axle shaft bearings?
I need to replace the bearings on one side of my rear end. Of course i will do both sides while i'm back there.
Is this the correct bearing? Is this the right seal?
Other than that, i need rear oil (how much?), gasket and bearing puller. Anything else?
