Is there any strength difference between motive 4.11's and richmond 4.10's (10 bolt)?
I've seen different opinions on the 37/9 4.11's and 41/10 4.10's. I'll take every bit of strength I can get since I'm still on a 10 bolt.
Or should I just throw in another set of 3.73's?
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I have heard of people getting the 37/9 4.11 as a substitute when they ordered 41/10 4.10s. I just checked Motive's and Richmond's online catalogs for the 7.5/7.625 10 bolts and neither lists the 37/9 4.11. Also checked Strange Eng. and Summit Racing....still no luck. Have you actually found the 4.11 ratio for sale?
They don't make a 4.11 for our rear end. We have 4.10. There will be a slight strength advantage on Richmond's side simply because of the way they cut their gears. Their cut is more aggressive yielding higher strength on the gear's tooth, but can lead to a noisy rear end. Motive's are kind of in the middle. They tend to be better (stronger) then a stock cut gear like GM/SLP/AAM, but have the potential to be noisier. Richmond does seem to get the nod for having the noisiest gearset around.....and I've had very good luck running Motive's stuff. I think you will find that you will snap a posi unit before you break the gears, or at least in my experience that seems like the more common failure point.
Seems to me that a 4.11 would have the same problem as the 4.56:1, with the small pinion, and the thick ring gear intruding on the cross shaft. That means weakening the shaft, the ring gear, or both, to get everything assembled. Now, in a stronger axle design that was intended to take 4.56:1s without issues, I have no idea of the 4.11 would offer any inherent advantage, or disadvantage, in ultimate strength.
There must be good reason that GM hasn't chosen 4.11 over 4.10 in the last 40 years.
Not when the pinion is so small it can only contact a couple teeth anyway. I busted 2 sets of 10/41. I didn't bust the 9/37, I removed them to put 3.90 in my car. I would actually recommend the 3.90 over both of them, the pinoin is much larger to spread the load like you say.
