9" BUILD THREAD!!! Come check it out UPDATED with pics
Old 03-13-2012, 06:58 PM
Whiteaw57's Avatar
Default 9" BUILD THREAD!!! Come check it out UPDATED with pics
Well the inevitable happened and I finally broke my 4.10 geared 7.5 inch rear end. I had one of the bolts shear off that holds in a worm gear for the torsen. Not sure how common this is but if anyone knows I am fairly curious. After some deliberation of just fixing it I decided to go ahead and fix it right and shove a 9 inch under it.
Here is the list of parts:
Quick Performance Housing
Moser Axles
Strange Nodular Case
4.11 Gear
Detroit Locker
Reusing Factory brakes and a UMI Trans mounted Torque arm
Im gonna post pics of the carnage soon!
I have a 4" driveshaft with 1350 yokes. Anyone have experience with fitting a 4"?
And what slip yoke to the trans is a good option?
Thanks in advance for the advice!
Old 03-13-2012, 07:13 PM
shepss217's Avatar
if you get one of QP's 1350 series billet yokes make sure you order the strange yoke spacer kit cuz i got mine and couldn't set the preload because the nut was bottoming out on the splines of the pinion gear, they machine further down where the pinion nut goes on, about 3/8" or so
Old 03-13-2012, 07:23 PM
flintwrench69's Avatar
Its common.
Moser Axles
4.11 Gear
Detroit Locker
Good choice with the 9. Let us know how that locker works with the M6, I was gonna go that route but they all say not with a manual.
Old 03-13-2012, 07:33 PM
Whiteaw57's Avatar
My third member is actually already together. I have some close NASCAR ties and got my third member built and I am not going to touch it. I expect some whine (10 bolt im sure was worse than the 9 inch will be) and I know it will lock hard when I get in the throttle but for what I got the Third member, driveshaft, and 5 gallons of fluid for I can't complain. My main question now is do I try to get away with a 60$ slip yoke for the trans, Buy a conversion U joint and use the stock yoke, or do I need to spend more on a higher rated one?
Old 03-13-2012, 07:49 PM
Whiteaw57's Avatar
Here are some pics of the 10 bolt. Sorry for bad quality to put the 9 in I will take a good camera.
This is what decided it didn't want to stay there anymore
Heres where the bolt head tried to escape
Heres where is came from
Old 03-13-2012, 07:51 PM
Whiteaw57's Avatar
Also looking at this
http://www.southwestspeed.com/?sec=view_part&id=30183
Old 03-13-2012, 10:25 PM
Whiteaw57's Avatar
This was 2 days before.......Oops
http://youtu.be/HLTBrutL6r0
Old 03-14-2012, 12:26 AM
01ssreda4's Avatar
Very common failure in the M6 cars.
Old 03-14-2012, 09:56 AM
shepss217's Avatar
yeah i would def. get a good hardened slip yoke, check out strange or pst
Old 03-14-2012, 05:47 PM
Whiteaw57's Avatar
Im honestly sort of proud I broke it just on street tires. I never went to the track and tried to hook it up. I guess I just beat on it too much.
Anyone ever have trouble fitting a 4" driveshaft?
Old 03-15-2012, 09:06 AM
ccrook19's Avatar
Same here i broke my 10bolt after about 10k miles of driving it, with seeing no track and less then 10 burnouts.. m6 + 10 bolt = accident waiting to happen..
Old 03-15-2012, 10:28 AM
shepss217's Avatar
yeah you got that right, i broke mine with an auto and stall converter pulling 1.6 60' times all day after about 50 runs or so she had enough
Old 03-15-2012, 12:47 PM
Whiteaw57's Avatar
I feel like you did pretty good. 1.60s 50 times.. Wish I could say that! I Want to get a good 1/4 mile time but the track prep is about 10 times better at the local 1/8th mile. Sadly leaving off idle I would only cut 2.0s or even 2.1 60s
Im assuming either no one has a 4" or no one had any trouble haha
Old 03-15-2012, 12:55 PM
Whiteaw57's Avatar
Shepss217 how do you like your spool? I have a feeling the locker will act a lot like it
Old 03-18-2012, 08:38 PM
Whiteaw57's Avatar
Axles came
hoping to have better success with moser than others have:
Old 03-20-2012, 10:18 AM
DANSBIRD's Avatar
I've got a 195k miles on my 10-bolt & it's an M6 car. I'm in this thread b/c it sure is making some noise and w/ a 6.2L about to be dropped in, I need to start getting educated.
Old 03-20-2012, 11:39 AM
shepss217's Avatar
i don't mind it, you only notice it taking slow tight turns other than that you won't even know you have it
Old 03-20-2012, 11:40 AM
Whiteaw57's Avatar
yes you do. Watch close my housing is coming in today!
Old POS is out
trying to decide on colors
As of now the housing will be red along with my UMI Torque arm. Panhard bar and LCAs I want to keep black. Driveshaft is white.
opinions on the third member color? options are either red or silver
Old 03-20-2012, 01:30 PM
Whiteaw57's Avatar
Just got word the car parts fairies just dropped off my housing. Can't wait to get home and start the party
Old 03-20-2012, 09:25 PM
Whiteaw57's Avatar
Heres the latest:
UPS droped it at some point
Problem now is I don't know how to install the axles
