Question about putting 3 channel rear in 4 channel car...
Ok my car is 4 channel.. I bought a 3 channel SS rearend.... I did a search and see it can be done my taking the 4 channel axles out and putting them in the 3 channel rear..
What will happen if i put the 3 channel rear in and NOT change axles,, No traction control i know but what about ABS??
so i'm assuming you don't need to change out the axles from the 4 channel rear end correct? main difference is just the plug for the abs/tc? I'm wanting to also purchase a 3 channel complete rear for my 4 channel rear/car. I will not have to trade out axles correct?
My cars a 4 channel car but abs is gettin deleted and traction control as well because a spool rear end wont work with eather system it wont hurt the car to not have eather one its just a personal prefrence and if u can put up with light staying on plus if chance to track tires with skinnies in front and 27-29 inch tall radials in the rear your abs will go crazy anyways
