3.73 gears question?
Old Jul 22, 2013 | 10:32 PM
Wayfastwhiteyaz's Avatar
Thumbs up 3.73 gears question?
I want to upgrade my stock gears and im not sure what to go with. Do i need a series 2 carrier my car is and A4 with 3.23 gears. i was planning on buying motive 3.73 gears what install kit should i go with?
Old Jul 23, 2013 | 11:48 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
an A4 with 3.23's would have/be on a 3 series carrier. 2 series carriers were used for 2.73s' and 3.08s'.
Old Jul 23, 2013 | 02:50 PM
so it shouldn't matter the carrier size with 3.73s?
Old Jul 23, 2013 | 05:35 PM
it's not carrier size,it's carrier series. But yes,carrier size matters when ordering gears for a GM 10 bolt. The common 10 bolt sizes are 7.5/7.625(4th gen f-body rearend from the factory),8.2,and 8.5/8.625.
Old Jul 23, 2013 | 05:37 PM
alexus6798's Avatar
You need to get gears for a series 3 carrier.
Old Jul 24, 2013 | 08:24 AM
mjs1012's Avatar
Get Motive gears in the blue box for a 3 series carrier and a ratech complete install kit. The part # is gm75373 for the gears. I used these in my rear and they are dead quiet so far after 200 miles.
Old Jul 26, 2013 | 07:29 PM
dboone2172's Avatar
Default Gear change
I"m putting the same gears set in that you did in a 2000 ss camaro, Did you do any computer programming, or is it ok the way it is .
Old Jul 26, 2013 | 07:38 PM
mjs1012's Avatar
Yes you'll need to adjust the computer to get the speedometer correct for the new gears.
Old Jul 26, 2013 | 08:06 PM
dboone2172's Avatar
Default Gear change
THANKS I have a SLP handheld custom tuned by diablo sport programmer , do you know if i can use it to change the speedometer correctiy
