stud install help!
Old Apr 27, 2014 | 07:35 PM
countryguy1717's Avatar
Default stud install help!
So I stripped a lug I bought all new ones. But I can't get the stud to fit.I have my torque wtench at 140, tried an impact gun but this is as far as it'll go. Could it be because I froze the studs before installing?
When I put the wheel on I stillgetabout6-7 good turnson lug beforeitgetshand tight.I'm just worried that they aren't flush.
I don't think its because my lugs are closed end because they have plenty of thread, maybe I'll go get an open end and try that.
Old Apr 28, 2014 | 06:53 AM
Paul Bell's Avatar
That's MISTER MODERATOR
https://ls1tech.com/forums/gears-axles-15/
Old Apr 28, 2014 | 05:33 PM
Originally Posted by Paul Bell
Whats the correct one? Wheels and tires? I tried there and got no replies so i thought general forum might be more suited
Old Apr 28, 2014 | 06:27 PM
Paul Bell's Avatar
That one stud's gotta go on more. It's head needs to be flush.
GM nuts have longer threads. Use some washers as spacers and grease the threads good.
Old Apr 28, 2014 | 07:28 PM
It still doesn't get flush. I shouldnt put any lube on the part that goes into the hub right?
Old Apr 28, 2014 | 07:48 PM
Paul Bell's Avatar
That's correct.
Old Apr 28, 2014 | 08:14 PM
That's correct.
I didn't lube it but I added three more washers and it worked! Thanks a lot! I can be back on the road again.
Old Apr 28, 2014 | 08:29 PM
Paul Bell's Avatar
Great!
You'd usually get some decent responses from your vehicle specific section. In your case, the Camaro section.
People with the same cars like to take care of their own.
I'd suggest you create a signature to show what you have and what mods-so people can see what you're working on (although this was a pretty simple fix).
