Vibration Problem, possible cause Pinion?
A dumb question, but would a failed CV joint or U joint cause that runout as well? Mainly, I'm thinking that rear U-joint. could be allowing the driveshaft to move, but still be solid on the yoke side, showing the yoke is still OK?
Another test if you end up ruling the driveshaft out - does it also vibrate in 5th, but not 4th or 3rd at the same speeds with the driveshaft in? The 5/6 gear can come loose on the countershaft resulting in vibrations. Pulling the driveshaft for the test you described also removes the tranny from the equation. I'm not sure you would detect a 5/6 gear vibration by the test you described, as the driveshaft would resonate the vibration, (though I agree, it would not explain the high runout on the rear)
Thank you
I agree the runout at the rear is problematic. The only way I can think that the driveshaft runout would be .045" and the yoke runout would be 0.005" is if that rear U-joint is bad. The two bearings attached to the yoke could be good, but the bearings attached to the driveshaft could be bad. Or a clip could be missing / broken off
The second video on drive shaft velocity is great. I'm surprised when you buy an adjustable torque arm it says nothing about this. Just: set to x for auto & y for manual.
I'll be checking this tomorrow.
The yoke is plausible, and there is a thread where the yoke was the problem for a user named "SpeedTigger"
Where I'm going is this. It's easy to move your pinion angle vertically. Imagine trying to move it horizontally with a 50' torque arm. You'd have to bend the rear axle assembly to get it to move. My point is that I don't think your body mounted torque arm is going to move the rear pinion against the axle sideways.
If you determine your axle is crooked you will need adjustable rear LCA's and an adjustable pan hard bar to correct it. However if your axle is crooked, your thrust line is off, meaning your car won't track straight, so you'd have an obvious alignment issue. Simply repositioning the torque arm won't move that rear pinion left or right. Only up or down.
If you are 100% certain on your driveline angles, then the yoke makes sense
I have a T/A relocation crossmember myself. Your idea sounds right. Maybe you just feel the vibes more now that your T/A is mounted to the crossmember.
