Click/creek in rear end
My '02 SS M6 (17k miles) has a creak/scrape noise from the rear end . It is more noticeable going 15 mph or so . It only happens going forward. It is not coming from the brakes. The noise comes and goes as you move . It has a diff from SLP in it I assume (according to the right hand door sticker). I bought it used last year. Where do I find specific SLP rear diff parts if needed? What kind of rear axle fluid do these need ? I read it is different than a stock rear diff.
Thanks
Thanks
Since it's an Auburn,regular Auburn parts,such as a spider set. How many miles on it ?,if the cone clutches are wore out,carrier needs replacement.
Regular non-synthetic gear lube and add GM/AC Delco limited slip additive. No synthetic lube for Auburns.
Have you checked the rear sway bar bushings for 'creeking' ?
clicking could come from the u-joint.
I jacked up the rear end,and turned the right rotor. I sounds like its coming from the rear end. What weight rear axle fluid need? The car has 17k on it. I can order parts right from Auburn ? I think the axle cover is silicone? Maybe its the u joint . I'll bring it into work , rear axles are not something I'm comfortable taking apart.
Well,I took it to work today. Put it on the alignment rack (it's too low for a lift) . Turns out that it was the right rotor. Apparently the parking brake part was mis-machined and it was hitting the parking shoes. Who would have thought?
