Post up your Driveshaft lengths for 9" ...
Just trying to see in my PST is longer then your usual 9" length for a 9" rear , mine is bottomed out on the t56 trans housing , from center to center on my Driveshaft , I'm getting about 42 1/4 inches , that's center of front cap to center of rear cap on the U joints ,,, let me know what u guys are getting , I know that must of the time a Driveshaft for a 9" is 1" longer then stock
I have a PST 3-1/2" alum. shaft that Eric ordered for me it fits T-56 to MWC fab 9". 41-1/2" CL to CL of u-joint and the yoke is 6" CL of u-joint to end of yoke. Make sure your housing is centered in the fender well. Hope this helps!
LS1Tech Sponsor
45.25 (x dimension) is typically the length for a 9 inch with a 4L60E or a T-56, measured with the chassis in the loaded position. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
While we're on the subject, I've always been curious about mine. I have a 3.5" PST custom length (don't remember the measurment). When installing it, it won't go into the transmission far enough to install easily. I have to play with it to get it to go into the rear end yoke. When removing it, i can only push it maybe 3/8" into the transmission. Not even enough to clear the yoke.
It's been in the car for a few years now with alot of hard launches. Hasn't caused any problems yet but I thought I'd ask. Does this sound right?
LS1Tech Sponsor
__________________
LS1Tech Premium Sponsor
Not one measurement will be exactly right or wrong for everyone.
A Strange chromoly yoke requires a different length than say a PST standard yoke.
A guy running a 28" tire with his MWC rearend cheated forward to center the tire will need a different length than his buddy with some poly ended non adjustable lowers with a Moser 9".
What I am getting to is that there is only one way to make sure your driveshaft is right for YOU. While we and others may have some numbers to use from sales history doesn't mean that those numbers are a standard for someone's particular combo.
The only way to properly measure a driveshaft is to get the yoke you are/will be using and shove it all the way into the trans. With the rearend at ride height and aligned(centered) properly, measure from the center of the trans yoke u-joint to the face of the rearend yoke and subtract 3/4" for an accurate center to center length.
If the yoke is not available then measure from the face of the rearend yoke to the back of the tailshaft housing(not the end of the seal). If we have that measurement and know the type of yoke used we should be able to get the proper number.
Be careful ordering a driveshaft off of a website that is setup for some aftermarket setup, your chances of incorrect length are very good. If you are unsure of what you have or need, feel free to call us. MWC is direct with Strange and PST, we offer the highest quality driveshafts and correct trans yokes for your needs.
Those of you with T56 transmissions with the stock 27 spline output you especially need to be careful. There are lot of aftermarket yokes out there that are being sold that are not the proper dimensions and will usually cause excessive vibes. We here at MWC have the correct yokes and driveshaft combos, and as always the best prices and tech help available!
