Strengthening the Torsen
After reading about a guy breaking 6 Torsens in stock cars I did a little research and found this article from Hot Rod magazine. Pretty interesting for modest powered cars. Anyone have any experience with this? Also would it be better to do this up front or wait till something breaks(if something breaks)?
https://www.google.com/url?sa=t&rct=...94XZwX19GTWWZw
nothing in the 'article' strengthens the Torsen.just concerns strengthening the housing to maintain proper gearset lash and using stronger axles. the Torsen itself cannot be strengthened. Since the Torsen is a carrier,at the end they 'recommended' going to an Eaton and/or Auburn carrier.
to see how a Torsen breaks,do a 'search' in this gears & axles forum for 'catostrophic'.
I'll look into that. Thanks. I'll make a few passes in the lower 12's (hopefully) after my stall and see if I'm drawn to seek 11's which will mean cam. If I'm drawn to more power, I'll hold off on any rearend mods and put back for a 12 bolt. I've had a lot of fun working on this car over the past 5 months. At some point, I hope to just be content with it.
Trouble with upgrading the stock 10 bolt Torsen carrier is instead of the carrier breaking the ring gear will break and the the housing will twist along with the tubes moving around. If you are going to do any serious beating the **** out of it replace the entire rear. I would upgrade to a Ford 8.8, very beefy and still on the light side of things overall. If you are handy you can do a 8.8 very cheap too.
I see Hawks has one cheap http://www.hawksmotorsports.com/hawk...-end-assembly/
I really appreciate the advice from everyone. It has really helped me keep my expectations in line with my car.
A4's have been into the 10's with a 10 bolt and a T/A cover. My car still has the 10 bolt and holding fine with motive 3.73 gears and a T/A cover. It was bottom 12's bolt ons only for years...now it has about 2200miles on it since the H/C/I swap and holding fine. It's not a track car tho....
