Humming Noise
I bought an '01 WS6 with 75k on it this fall and one of the things that has developed since I put about 900 miles on it was a hum from the back of the car.
The humming is based off the speed of the car, not the revs of the engine, and becomes audible after about 40-50 mph.
I thought it was the diff, but I had a master mechanic open up the diff and he said everything looked good. We filled it up with fluid again and off I went.
I then got an alignment (car was pulling left), but that also did not fix the humming (and the car still pulls left a little bit).
A couple suggestions that I received was to take it back and have the alignment double checked, that the frame might be bent, or that the U-joint needs to be replaced.
I was wondering if anyone had any other thoughts or suggestions to share.
Many thanks in advance...
Mike
Now my truck made a whine at 45 mph and higher only under acceleration, that turned out to be bad pinion bearings which have turned out to be a massive head ache as am trying to rebuild it for the first time with help from the guys here.
that's just my two cents as you stated its coming from the rear, I still have my OEM U-joints at 222,000 miles, and am hard on them.
