Help me pick a gear
2002 WS6
Automatic - 4L80E
LS1 stock bottom end
Advanced Induction stage 2 243 heads
Fast 102 intake
Tick stage 2 turbo cam
Single 7875 billet turbo - running up to 10psi to keep bottom safe
Circle D 245mm 4000 stall multi disk
Estimating I will make between 600 and 650hp and that's plenty for me
Will be running a radial drag slick on 10" wheel
I am told turbos like higher gears in the mid 3's but I was thinking 3.73 or 3.90
Let me know your thoughts out there, especially if you have similar setup..
Tire size currently 275 R 15.. probably be something similar going forward...
be a 90% bracket racer 1/8 mile.. some street time for entertainment only.
If bracket racing I'd go with a taller gear to ensure traction and let that turbo eat in third gear to make some mph.
Have you bracket raced with the turbo much? Consistent?
what kind of times are you getting in the 1/8 with similar setup? you like the TH400 over the 4l80e? I was thinking of swapping that out too to drop an easy 100 lbs.. especially if I go with a higher gear.
