Needs Pic's Of Backing Plates Installed
Old Nov 23, 2017 | 11:22 AM
  #61
Driver2's Avatar
Spoke to soon! It's keeping it in place just enough to not rub the enter fender but I jack it up today to find out what my rubbing noise was which was my brake caliper bracket rubbing the rim which i used a grinder to fit that problem but after having it jacked up working on that problem i noticed the pass-side wheel was closer to the front side of the fender well so i took a plumb bob and rechecked if anything had changed and the drivers side was sticking out 1.5 inches more than the pass-side even though i set both sides equal using the plumb bob. I don't get it. I'm going to pull axles back out tomorrow and see what the hell is going on. What A NIGHTMARE.
Old Nov 30, 2017 | 07:35 AM
  #62
Dwalt79's Avatar
Curious any updates?
Old Nov 30, 2017 | 07:39 AM
  #63
Dwalt79's Avatar
Don't really see a sway bar affecting side to side movement especially with heim joint end links that will pivot side to side easily. With you saying jacking the vehicle up...keep in mind as the body raises the further the rearend drops the more it will move forward and to the side that the phb is affixed to the body
Old Dec 2, 2017 | 04:55 PM
  #64
Driver2's Avatar
Originally Posted by Dwalt79
Don't really see a sway bar affecting side to side movement especially with heim joint end links that will pivot side to side easily. With you saying jacking the vehicle up...keep in mind as the body raises the further the reared drops the more it will move forward and to the side that the phb is affixed to the body
I think thats what was going on.
