Do I need to dump the fluid again?
Why did you have to change the posi unit ?
What posi unit did you put in ?
The ring gear was removed from the original posi unit and put on the new posi unit. Did you go with new carrier bearings ?
Did you check 'lash' ?
Did you use an aftermarket cover to be able to drain the fluid without having to remove the cover ?
If you put in an Auburn posi(metal cone clutches),I'd recommend changing the fluid. The 'break-in' of the Auburn's clutches will put those particles into the fluid.
I was hunting a vibration and there excessive play when rotating the wheels back and fourth while the car was on a lift in the air. Also, something metal was banging when I would go over a bump which is now gone. The play is also better but the vibration turned out to be uneven permanently flat spotted tires.
What posi unit did you put in ? I wish I remember, I was put on the phone with the tech guru @ Quick performance in IA (recommended by a friend). He said he knew what I had and I purchased an assembled posi kit. I believe it came with the bearing kit because it was around $400 bucks for the parts. It was a rush to get the parts because the car was stuck on the shops lift.
I don't think the ring gear was removed but I did not see the actual install, each time I went it was still in the car.
Did you check 'lash' ? I am assuming my mechanic did because it feels fine and there is no whine or humming that I hear.
Did you use an aftermarket cover to be able to drain the fluid without having to remove the cover ? Yes
1999 TA would have come with a Torsen posi carrier,it would be nice to know what the replacement posi/carrier is.
The ring gear would need to have been removed from the previous posi/carrier and installed on the replacement posi/carrier.
Since the car originally had 2.73s',which would have been on a 2series posi/carrier,3.42s' would have required a 3 series carrier OR the use of a 'thick' 3.42 gearset. This is just info being passed on and has nothing to do with current.
'There is no whining or humming'-that is good
'there excessive play when rotating the wheels back and fourth while the car was on a lift in the air'-since it was the original Torsen posi/carrier probably used for the 3.42 gear swap,that excessive play is typical of a Torsen. They have that 'excessive play' when new. Play on a torsen needs to be checked by rotating the driveshaft and watching the play in the rotation of the wheels. It's a common misconception when trying to evaluate a Torsen by old school mechanics that are used to Eaton and Auburn posi carriers. This is not intended to 'belittle' the shop/mechanics you used.
'I don't think the ring gear was removed but I did not see the actual install, each time I went it was still in the car.'-did you happen to take a pic of the new posi/carrier ?
Side note:
I got a diff from a stick car that had the 3.42s in it so I guess I do have a 3 series carrier.
I work on rear ends,since the 60s'. But now it's just the little F-body 7.5/7.625" 10 bolts.
I had the day off today so I called Quick Performance. I have a Yukon clutch style posi unit and I did buy the master bearing kit. It is not an Auburn but since it has clutches I should change the fluid? I feel better at least knowing what I have now. Thank you.
Auburn is a metal-to metal clutch,that one is spring pressurized plates-metal plates to non metal plates.
How many miles on it since the work was done ?
That design is similar to the Eaton positraction that was used in many cars from the factory and how many of those ever had the fluid changed ? I doubt 1 percent.
Only reason you'd be changing it would be to get the clutch's break in particles out and since the carrier/positraction was replaced(even though it's running quiet),the gear mesh does not perfectly match the previous mesh and that'll produce a new wear pattern which'll dump metal into the fluid. But not enough to worry about.
