Leaking 10-Bolt?
Old Jul 18, 2018 | 01:07 PM
INFERNY's Avatar
Unhappy Leaking 10-Bolt?
So I noticed recently that my 10-bolt has been looking a little damp around the bottom of the differential cover. I'm assuming it could be the gear oil seeping through. However, it if is a leak it is very small because it doesn't drip on the floor at all. Is 10-bolt leakage a common problem on F-bodies? Is it a precursor of bigger problems to come?
Most people on the Facebook forums say that this is a common issue and that it's nothing to worry about. However this is the first time I've heard of this "common issue".....
Old Jul 18, 2018 | 01:41 PM
SRT8.Acelleration's Avatar
Yep, once they start leaking you have to replace with a 9" or 12 bolt...
Old Jul 18, 2018 | 02:44 PM
ss.slp.ls1's Avatar
If it's not whining or clunking then pick up a new gasket and some gear oil and drain and refill. It helps to have a silicone hose to fill the diff.
Old Jul 18, 2018 | 03:35 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Not common and not rare. If it's the gasket that's 'seeping',possible to 'snug' the bolts as a gasket will set/compress over time and the bolts might not have the required torque/tension on them. Also possible the pinion seal is weeping and running down the case to appear as it's a gasket leak.
Only precursor of a bigger problem is that if so much leaks out that proper internal lubrication is not occurring.
You didn't say what kind of car and year ???
Old Jul 18, 2018 | 04:24 PM
INFERNY's Avatar
It's a 2001 Z28 with the T-56. I just took her out for a drive and it seems the slow leak is coming from one of the bolts on the rear diff cover. It isn't coming from the gasket. I'm assuming the bolt might just not be tight enough.
First time I've seen this happen since I changed the fluid and gasket back in November 2017
Old Jul 18, 2018 | 04:25 PM
INFERNY's Avatar
Yeah it's not whining or clunking thankfully
Old Jul 18, 2018 | 04:41 PM
A 2001 Z28 would have a Torsen posi and doesn't require the 'additive' as a 1998 and earlier Auburn posi does.
Gear oil is smelly smelly smelly so be prepared to thoroughly wash your hands with a good degreaser.
Old Jul 18, 2018 | 07:30 PM
INFERNY's Avatar
Oh yeah I know I changed the fluid back in November and it was nasty as hell. I'm just gonna go and retighten the bolt and see if the leak persists
Old Jul 18, 2018 | 08:51 PM
INFERNY's Avatar
Here's a picture of where it's leaking. As you can see it's a very slow leak. Everytime I drive her it drips like that. Never enough to wet the floor, but enough for it to be noticeable on the diff cover. It's not coming from the gasket and I retightened the bolt yet it still does it. Should I just use RTV sealant on the bolt?
Old Jul 19, 2018 | 09:54 AM
DANOZ28's Avatar
about every 3 years my pinion seal starts leaking. maybe its time for a shiney new rear cover?
Old Jul 19, 2018 | 11:06 AM
Chrisingermany's Avatar
Another quick thing you can check is to see if the breather is blocked with dirt/oil. If it is, pressure can build up and force oil out the seals. The breather pulls out easy enough and can be cleaned and worse case scenario the orifice can be enlarged.
Old Jul 19, 2018 | 11:40 AM
^^^ good point,forgot about that potentially being blocked and when the rear warms up from use a slight pressure builds inside causing the pressure to find its' easiest way out.
Old Jul 19, 2018 | 01:28 PM
INFERNY's Avatar
Where is the breather? Or what is it exactly? 😅
Old Jul 19, 2018 | 01:51 PM
Not the greatest pic but you can see the little off white nipple sticking up just off the right side of the center area.
Old Jul 19, 2018 | 07:00 PM
INFERNY's Avatar
So do I just pull off that white plug? And then just clean it?
Old Jul 19, 2018 | 08:10 PM
It's pressed in at the factory,but not much of a press fit. It's fragile 'plastic' so carefully pry it out. If successful in removing it,yes just clean it.
Some rears I've encountered,already broken.pry/extract the broken piece. The hole that it's in is a 7/16" diameter hole. Some rears I just forced in a length of rubber automotive hose and tied the hose to the panhard bar upper mount,never came out and never had excess coming out of the other end of the hose,it's just there to vent heat build-up pressure. Some rears I tapped the hole(1/4 npt is perfect for the hole) and screwed in a barbed hose fitting.
Old Jul 19, 2018 | 08:12 PM
INFERNY's Avatar
So I went underneath the car and looked all over and I still can't find it. Felt the entire diff top to bottom and side to side. There wasn't anything remotely close to a white tube like the one in the picture. Are you sure all 10-bolts have them?
Old Jul 19, 2018 | 08:18 PM
INFERNY's Avatar
Alright after about 10 mins of searching, I found where the breather should be.....
...I found the hole but no breather
So now what? I don't know why there isn't a breather, but since I don't have one at all should I just clean the hole??
Old Jul 19, 2018 | 08:20 PM
Replying to post #17. They're white when new but don't expect to find a white vent plug. As they vent fluid,it becomes oily and holds any dirt that contacts it. They're always black/filthy. Or could be it's already broken off OR already removed and the hole just plugged.
