Eaton TruTrak Problem?
I used to think this was a suspension problem, and made some changes to try and fix it. But now I'm thinking it's really a differential problem.
I have two corners at High Plains Raceway that are the biggest problem; turn 2 and turn 11. Turn two is a flat single radius somewhat tight right hand corner. Turn 11 is a decreasing radius, slightly banked wider right hander, that is mostly uphill (love this corner).
In the corners, the inside (right) wheel spins until the car is pointed straight. Then it hooks up and goes. If I feather the throttle, I can keep the tire from spinning, but that costs me time. If I keep my foot in it, I can feel that tire spinning, but the car still accelerates, and I get a quicker lap time. Especially in turn 11, the tire will actually leave a long black mark, about a car length long or so. It's sort of acting like an open differential. But the car does accelerate, so power is getting to the left wheel.
In theory, the Eaton should sense that the right tire is slipping, and transfer power to the left until the right wheel isn't spinning any more. Then when both tires are getting traction, it should work like an open differential. But that doesn't appear to be happening.
Do you think this is a differential problem? Or is it still a chassis problem? Is this a somewhat know failure of the Eaton Gear? I did a google search but couldn't find anything.
Having said that, does the car try to pick up the inside rear wheel under corner entry?
