MWC install. Is this chattering normal?
Old Nov 15, 2022 | 04:33 PM
Need4Camaro's Avatar
Default MWC install. Is this chattering normal?
the installer used my stock drive shaft with a different U-Joint. I am thinking I probably need to upgrade… I’m not sure if this sound is normal for an aftermarket rear…
Old Nov 15, 2022 | 08:39 PM
99 Black Bird T/A's Avatar
My friend's MWC doesn't make that noise.
What type of limited slip/posi is in the carrier? Is chattering worse when turning?
If it's a clutch type maybe it just needs the limited slip additive.
Old Nov 15, 2022 | 10:19 PM
I went with the S-Trac. It doesn't make the sound when turning. Its most noticable at highway speeds. Doesn't really do it at lower speeds.
Originally Posted by nikon1999
Your pinion angle might need to be adjusted if that wasn’t addressed.
The installer adjusted it and the vibration is mostly gone ... just this odd sound remains.
Old Nov 16, 2022 | 09:21 AM
ramairetransam's Avatar
my fab 9 from them doesnt make that noise either. my mwc fab 9 came with a driveshaft , what tq arm to do have ?Almost sounds like something hitting , your exhaust , is everything tight . I want to try and help you figure this out . you need to get it on a lift or up in the air
Old Nov 16, 2022 | 10:09 AM
I used their torque arm:
Torque Arm & Crossmember Options: Short Arm True Dual Crossmember (Two Piece Arm Needed Double Wall Higher HP)
I have Speed Engineering True Duals over the axel so it may be exhaust? The installer told me it fit like stock but they rattled a bit stock too, but I never got this sound until I installed my MWC.
Old Nov 16, 2022 | 08:01 PM
Spankstangs1999's Avatar
Sounds like exhaust hitting. Do you have a drive shaft loop?
Old Nov 17, 2022 | 07:18 AM
i have the se true duals and mine only hits on larger bumps where it goes over the axle housing . also i will add my exhaust it a red c hair away from the driveshaft but its never touched it , well a red c hair when its on my lift and the axles hangs down . those duals are very large and very close , it almost sounds like a chattering of the exhaust on something .
Old Nov 17, 2022 | 07:47 AM
Yeah, I have a drive shaft loop. What is a good way to check the exhaust hitting stuff? my exhaust rattles alot during idle.
Old Nov 18, 2022 | 12:49 PM
shake on the tips and listen , if you know its hitting you have to fix that first , did you have this sounds before the duals ?
Get it up in the air and check it out .
Old Nov 18, 2022 | 01:10 PM
Your torque arm could be touching your driveshaft loop. I had that issue.
Old Nov 20, 2022 | 11:03 AM
91 Z28's Avatar
Mine doesn't make a sound while driving. The only noise that comes from my rear is clicking from my Yukon grizzly locker when taking a corner
Old Nov 26, 2022 | 06:31 PM
How did you fix?
Old Nov 26, 2022 | 08:31 PM
How did you fix?
Mwc wanted me to send in. But life got crazy. I ended up just putting some radiator hose where it was touching.
Old Nov 28, 2022 | 11:32 AM
Y2K_Frenzy's Avatar
For the non DIY guy it’d probably be cheaper to ship them the whole car. 😂.
Old Dec 28, 2022 | 07:46 AM
I'll probably see about going to MWC in Spring.
