10 Bolt worth builing?
He's taken his stock 10 bolt into several 10.4 200 shot nitrous passes with just a TA girdle on a 28" W ET Drag.
I'd be running low 11s/high 10s NA with a 26" or 27" tire.
He's recommending a TA girdle, Auburn Race Posi, and a 4.30 gear for N/A.
Should I just save up for a 12 bolt until this one breaks, or would it be a good idea to spend <$1,000 on building my stocker to hold up? Thanks.
and gear swap supplies. Before that, welded tubes
and a MAC girdle. So I'll have half of the cost of a
12-bolt into it in the end.
Not figuring on huge HP or drag radials though, just
the best street tires I can find and someday a baby
cam and maybe a small shot.
Dan
I've been running slicks for a while with countless hard launches. I'm cutting low 1.5 shorts, but maybe I should invest in a TA girdle. My tech suggested that I weld the spyder gears and make my posi a "spool". He said it will launch more consistently and that I have nothing to loose. Should I do that or buy an Auburn race posi? What do you think? Thanks.
It depends are you big in drag racing? do you mind you won't be able to make tight corners? if not go for the spool, otherwise get the race posi.
Dan
If I were you I would just run the Posi till you break, then get a 12 bolt with a real spool, I don't think I would weld something to make it act like a spool but that is just my opinion. Also I am like you running around I never take hard corners, no sway bar, but I am still on 17" wheels but I am all out for drag racing
, don't care for corners otherwise I would own a Vette!Dan
You can put fancy carriers, fancy axles, weld fancy brackets on the tube, and put fancy gears in there. The gears are still small, ESPECIALLY 4:10's +, and you WILL break them sooner or later. Most of the time, sooner than later.
A 10 bolt is NOT worth spending several 100's on. Maybe throw a set of gears and decent carrier in it for some fun if you're tired of the 3:42's, but when it breaks just move on. Take this advice from someone who's spent over 3000 dollars on 10 bolts before waking up to reality.
