Aluminum 9" center section....street worthy?
I currently have a Moser 9" with a nodular iron center section, and I was trying to find some ways to cut the weight from my car. I have talked to Strange and they said not to run the aluminum center sections on the street. They said you will experience shorter gear life. I asked him why and he couldnt tell me, just that it was what he was trained to say.
How many of you run them on street, say 2500-3000 miles a year? I would like to do the lighter center section and also lightened gears. I need some opinions.
Brian
Brian
14 Second Truck Club
You have to consider that a set of rear gears in a normal passenger car aplication can easily go over 150-200,000 miles if they are maintained. When they say reduced life that could be a mileage that you may never reach. Plus, the abuse would be more of a factor in limited gear life than the aluminum housing. If it were a heavy 4x4 with 35" plus tall tires it would be more of a factor.
Thanks for the opinions so far.................It looks like its leaning towards the aluminum center section. SInce I already have my Moser nodular one sold..........this will work out good.
If you are going to change to an aluminum center section, what differential are you planning on using. If you are going to run a spool, you may want to check out Strange's 12 bolt aluminum center section (35 and 40 spline are only available with a spool, 33 are available with a posi). It will supposedly bolt in place of the 9" center section, weighs 8-10 lbs less than a comparable 9" and is 3% more effeceint. I suspect it will require different length axles as well since ford uses odd ball length axles.
