Question about 10 bolt
Old Nov 24, 2004 | 03:29 PM
texasuperman's Avatar
Default Question about 10 bolt
how much horsepower will a stock 10 bolt hold before it snaps
Old Nov 24, 2004 | 05:53 PM
1ScrudeDude's Avatar
Almost too may factors to list. An A4 will last longer. Also depends if you launch hard, and with sticky tires. Speedshifting won't help either.
I have read that even a stock motor has crapped the pumpkin. If I had to put a number on this I would say 350rwhp and up.
But this question is very broad. I say save up the $ and get a 12 bolt or 9".
Old Nov 24, 2004 | 06:40 PM
M6HuggerSS's Avatar
well look at my sig.... with 400rwhp and 375rwtq i still have the stock 10 bolt and stock clutch, and 4:10 gears....
id say its all in how you drive your car..... me im not to hard on mine....
though id like to get some DR and a better clutch and after that im not sure how long it would last...... but like i said its all in how hard you beat on your car!
Old Nov 24, 2004 | 06:50 PM
this is the problem i'm putting an ls6 in my 98 v6 firebird its pretty much stock except for headers. but don't know if i should keep my v6 rear end till it snaps, buy and ls1 rear end, or by a 12 bolt rear end?
Old Nov 25, 2004 | 02:53 AM
CountryMuzicZ28's Avatar
on my 6th one.... 1 axle, one posi unit (broken spider gears), one pinion head.. that was on heads and cam. Now with the new motor I have broken the gears, wait uh.. shatterd the gears twice.. lol. Do it myself so not too much money but is quit annoying.. Get a 12 bolt and dont try to save the ten bolt.
Old Nov 25, 2004 | 08:00 AM
speedo's Avatar
I almost stuck the money into mine last weekend. Thick gear, install kit and TA cover. Poped the rearend cover and we looked in there and it looks like a baby rearend. Thought no way...........! Sold all that to a friend and going with a 12 bolt in the spring. Wish I could find an decent 8.8...
Old Nov 25, 2004 | 08:35 AM
02WS6Bird's Avatar
you might want to try SLP's 12 bolt...that is if you want a posi...otherwise mayub moser does his for there own
SLP has a 12 bolt Eaton posi 33 spline with 8.875" axles...not sure if everyone does that but it cought my attention
Old Nov 28, 2004 | 11:50 PM
Matt D's Avatar
Retired Street Racer
i know of people spraying a 200 shot on the stock 10 bolt, no problem. automatics are more forgiving than m6 though....just change the fluid often, and change the gears once a year, and you should be fine.
Old Nov 29, 2004 | 12:26 AM
badjuju342's Avatar
Deranged Rat Fink
10 bolts+ slicks or drag radials= KABLOOEY!
Old Nov 29, 2004 | 12:41 AM
2MuchRiceMakesMeSick's Avatar
I have seen them break on a stock car. Try searching, its fun
Old Nov 29, 2004 | 07:40 PM
Mike98WS6's Avatar
It's like a ticking time bomb with these rears. That's why I'm saving up for a 12 bolt.
Old Nov 29, 2004 | 10:29 PM
chevymec's Avatar
I 've got 28 spline axles, Eaton Posi, 4.10 gears (2nd set), LPW cover and brace kit, amd all Spohn suspension parts in the back. I broke the 1st set of gears after about 60 -70 passes at the track with Nitto 555R's that were worn out. Dont know what I launch at exactly but its probably about 4K. Im gettin 1.655-1.670 60' . With the money that I put into this I could have gotten the 12 bolt but I put it together over time.
Old Nov 29, 2004 | 10:30 PM
chevymec's Avatar
oh yeah 10bolt =
