Break a 10 bolt from a punch?
My quesion is on a hi HP car if you are on the highway or cruising around 30mph and you floor it how hard is that on the rear end? Can that break it?
but no luck
I put 26x10.5x16 MT ET STREETS on the WS6 and it has a SPEC stage 3 carbon clutch also. This track isn't your top notch NHRA facility...if you know what I mean. We went on a early spring saturday(if I remember right it was either the opening weekend or the following weekend). The humidity was high due to the moist ground and the track crew didn't even glue the track, not even the starting line! They did however have two small dribbles in the box. I dumped the clutch at 6000rpm each time and powershifted all the way to 4th every time but she never broke
So hopefully you'll get lucky like that too!
but no luck
I hope you are right about the auto cars
but no luck
So hopefully you'll get lucky like that too!If i was you and I broke my 10 bolt they would probably tell me the warranty is void because of the excessive abuse that I put on it. Thats just my luck.
I have BFG DR's and a good 150 passes on a stock 10 bolt with 3.73's and an LS6 clutch leaving at over 5000 rpm.. (making between 345-370+ rwhp) I think the key is either luck, or being able to slip either the tires or the clutch.. or both. I "slip/dump" the clutch to take the shock off the rearend and leave at a high enough rpm to get the tires to spin enough to get the car not to bog. I've cut a best of 1.81 60' on BFG's this way at a notsogood track.
Nobody can say for sure. 10 bolts overall are junk, but there's a few that came straight outta hell and wont break for ****....
eventually everything breaks especially a 10 bolt w/ any kind of power go 12 bolt and wait longer for it to break. as for the members running 10s/11s I bet they dont last one whole season.is that worth that little bit of weight saving to keep break rears ?
but no luck
So hopefully you'll get lucky like that too!Anyway, later down the road we kept messing with each other jumping back and forth and I didnt notice anything until I pulled off the exit ramp to go home and mr rear was popping. I pulled the cover off later and found some small pieces of the spider gears. I removed them and filled it back up with fresh fluid and still drive it but I havent been snatching on it like that. I need a new posi unit.
