To 12-bolt or not?
This kinda pisses me off, because I'd like to keep the streetability of a posi in a 12-bolt, but also want to make some runs down the quarter without worrying that my rear is going to give.I thought the point of getting a 12-bolt is to not have to worry about it anymore. I'm currently saving up for a Strange 12-bolt and have done some research on rears.
I guess what I'm trying to ask is will I be picking my 12-bolt up in pieces after a few hard launches at the strip. I plan on adding a nice set of heads in the near future and want to be able to get some nice times. Anyone else in the same boat as me? What are us M6 guys to do? I got Strange thinking I can dump at 6k with slicks with a posi. From reading this board, I am now finding out that I am still not bulletproof.
So I guess WHEN I break the posi, it will be spool time
. You can always go the 9" route with a locker. Last edited by 1ScrudeDude; Feb 23, 2005 at 03:33 PM.
So I guess WHEN I break the posi, it will will be spool time
. You can always go the 9" route with a locker.Scrude, what kind of abuse has your Strange been through? (what rpm dumps are you doing, what tires are you running) Any problems yet?
Needless to say I lost the race
I didn't "get out of it" either, because it didn't dawn on me that I grabbed 2nd instead of 4th. My rear locked up, I smoked the tires, got sideways, and my mirrors were shaking when I looked back, preparing to see the "yard sale" on the track. And I think I shook a filling loose from my tooth. (Ok that was an exaggeration, but you get the picture)I also had bad cases of wheel hops with my Nittos. Wheelhops KILL rear ends. So far mine is alive. I dumped the Nittos, put in LCA's and now all is good.
Like you, I have 3 channel which means yes, we are screwed (hence my screenname) for the 9".
Ok, now there is some good news. I don't think of myself as any kind of pioneer, but a recent experiment yielded good results:
I use a Harlan Two Step with my launches, and I think it reduces drivetrain wear. With the Two Step, I don't have to load up on the rpms to get a holeshot. With this device, you preset your desired rpm for the clutch dump. At the same time, your gas pedal is to the floor. As soon as you dump that clutch, you are at full throttle.
I preset my Two Step at around 3500 rpm, which is the middle ground between spinning and bogging. I got great launches last weekend when I first tried this. You see what I'm getting at? Better to dump out at 3500 rpm than 6000 to get a good hook. The only other requirement for this to work is to have a sticky tire, Nittos notwithstanding. I got MT DR's and they are great.
BTW, my Strange howls loud at 65-75 mph now, but it probably wouldn't have if I didn't misshift and wheelhop for 10 passes.
so are the only options for the 12 bolt the eaton posi or a spool?
What would you say the performance breaking point of the 12 bolt posi would be (w/ M6)
thanks
It has been for me. If I dump higher than 3900 on Mickey Thompson DR's at 18 psi, I SPIN!
My range, depending on track prep and weather, is 3300-3800.
