What should the pinion angle be set at?
Old Mar 23, 2005 | 12:43 PM
00RedWs6's Avatar
Default What should the pinion angle be set at?
Im about to put a 12bolt in the TA and was jw what the pinion angle should be set at? Its a 6spd
Brian
Old Mar 23, 2005 | 01:49 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Brian
-2 works good for my ride. Thats measuring from the pinion flange with the driveshaft off with a digital angle finder, ( smart tool ).
Old Mar 23, 2005 | 04:50 PM
Mark98SS's Avatar
-2 relative to what? I know this has been discussed at length, just want to be sure.
Thanks,
Mark
Old Mar 23, 2005 | 09:44 PM
racinbird's Avatar
Measure the stock angle before you remove it.
Old Mar 23, 2005 | 10:57 PM
wrencher's Avatar
wrencher
This is the proper method;
http://www.rosslertrans.com/Tips/Pinon.htm
Remove the drive shaft & get the angle mesurment from you output shaft/yoke on trans. Now adjust pinon accordingly.
Old Mar 23, 2005 | 11:07 PM
LS1Tech Sponsor
Thanks,
Mark
A drive on hoist that is level to start.
Old Mar 29, 2005 | 04:38 PM
Mark98SS's Avatar
Ever since I changed to a locker in my 9" I've had wheelhop problems. I've screwed around with the pinion angle following popular measuring & adjustment techniques. I measured the trans angle, the driveshaft & the pinoin & set the angle -2 relative to the trans as many "how to's" say to do it. Still had wheelhop & cranked down another 2 degerrs & still was hoppin. Today I set it -2 relative to the ground, to hell with the rest of the drivetrain & guess what? No more wheelhop. Today's total adjustment was about -3 degrees from where it was, I'm amazed at the difference
Old Mar 29, 2005 | 07:41 PM
B18B1LS1's Avatar
Adjust it from the ground on a level surface, not the driveline. You want around -2 for a street car.
