Please Guide Me!!!
Old Dec 6, 2001 | 04:30 PM
Nate Dogg's Avatar
Default Please Guide Me!!!
Would someone please guide me to a site or something that would tell me the difference between a posi and a LSD. Also a site that would explain how a T-brake works. Thank you very much. Nathan
Old Dec 6, 2001 | 08:17 PM
Nate Dogg's Avatar
Default Re: Please Guide Me!!!
ttt pleazzzzeeee <img src="images/icons/frown.gif" border="0">
Old Dec 6, 2001 | 08:29 PM
Sears's Avatar
!Dial-up Director
http://www.howstuffworks.com/differential.htm
Old Dec 6, 2001 | 08:36 PM
Nate Dogg's Avatar
Thanks. I've been to that site before but it was a while ago and I had forgotten all about it. Thanks man!!!
Old Dec 7, 2001 | 12:04 AM
Colonel's Avatar
A "posi unit" and "limited slip"...same thing just too different ways to word it.
A spool, on the other hand, allows NO differential in speed between the axles.
A T-brake basically engages 1st and reverse at the same time. Since they are the same ratio the net effect is zero power going to the output shaft no matter how much throttle is applied. When the T-brake button is release the reverse part of the equation is also released which = SUDDEN forward momentum! <img src="images/icons/shocked.gif" border="0">
Old Dec 7, 2001 | 09:43 PM
Nate Dogg's Avatar
Thanks. But which is better a spool or posi?
Old Dec 7, 2001 | 09:50 PM
SC 98 Mecham's Avatar
[quote]Originally posted by Nate Dogg:
<strong>Thanks. But which is better a spool or posi?</strong><hr></blockquote>
This would depend on if you wanted to drive around corners. <img src="images/icons/grin.gif" border="0"> Jason
Old Dec 7, 2001 | 10:24 PM
AAron's Avatar
even a soft locker dosent like corners unless you like your corners in the goin sideways variety <img src="images/icons/grin.gif" border="0">
i put an auburn posi in my 9"
