just got the 3.73s installed
I have an A4 with 273s and I am planning an upgrade. Considering 323, 342 and 373. I am a little worried about top end/gas with the 373s as I do a daily highway commute. How do you find the 373s? Is the engin reving alot when driving at higher speeds? Any comments would be appreicated?
JA
i had mine installed for $250.
The proper way to break in rearend gears is to vary speeds between 45 & 60 MPH for the first 100 miles, not driving the vehicle more than 25 min at a time. Have at least a 30 min cool down period.
For the next 400 miles vary speeds not exceeding 70 MPH, with a 30 min cool down period.
At 500 miles drain and refill differential, and your good for 50K.
During the initial break in period, the ring and pinion gears are meshing together, and will run hotter, and shed small pieces of metal (more like silt). If you do not break in the gears properly you have the chance of searing the gears, or warping them due to excessive heat.
JMHO
SteveC
