which gear set is better
IMO, It's a good compromise between 3.23's and 3.73's. You will still get decent mileage and you will see a good difference from 2.73's.
You can get those gears pretty cheap from any M6 owner who is swapping them.
Install should cost you around $150. Add another $75 or so if you change your bearing set (recommanded). Also, you will have to reprogram your PCM with the new ratio or your speedo will be off with the new gears.
