Ok, New Idea........
Old Jan 10, 2002 | 02:17 PM
Marty's Avatar
Default Ok, New Idea........
Think I might hold off on the t-brake till I install the the good ole 9". So I am probably gonna get the 2.75 first. Is this a good idea? How much will I benefit from using the 275 first? I just think the drop from 3.06 to 2.52 is a little to big. Ok well give me you input:
2.75 first Good Idea/ Bad Idea and why
Marty
p.s. - are these 350's w/o t-brake's harder on the stock rear than the 4l60's? <img src="images/icons/confused.gif" border="0">
Old Jan 10, 2002 | 03:16 PM
BIGBOS's Avatar
Default Re: Ok, New Idea........
I am sticking with the stock first gearing on the th400, I would just get the t-brake and not use it and wait until you get the 9"
Old Jan 10, 2002 | 08:23 PM
Ragtop 99's Avatar
I like the 2.75 better than the 2.52, but I still run a 4L60e and speak from theory, not experience. Probably depends on your converter, gears, tires, and torque curve if you want a truely optimal answer.
Old Jan 10, 2002 | 08:27 PM
BIGBOS's Avatar
I would rather spend the $$ on getting an OD gear than getting a different gear ratio
Old Jan 10, 2002 | 08:33 PM
Marty's Avatar
I don't really need the OD and I truly "think" the 2.75 will help in the long run. Just from a theoretical stand point, the 2.75 would be stronger off the line and allow me to run a less extreme rear ratio. Please keep the comments comin guys.
Marty
Old Jan 10, 2002 | 08:38 PM
BIGBOS's Avatar
Well if you are going to be basing everything on drag racing, then I would go with that...I plan on having my car out everyday when summer rolls around... <img src="gr_grin.gif" border="0">
Old Jan 10, 2002 | 08:40 PM
Marty's Avatar
[quote]Originally posted by BIGBOS:
<strong>Well if you are going to be basing everything on drag racing, then I would go with that...I plan on having my car out everyday when summer rolls around... <img src="gr_grin.gif" border="0"> </strong><hr></blockquote>
I feel ya man. I'm gonna be crusin at bout 5k <img src="gr_sad.gif" border="0"> Oh well <img src="gr_tounge.gif" border="0"> Oh just FYI guys this is strictly a drag car. Ok......well it maybe a slow drag car <img src="gr_sad.gif" border="0"> ......but it's still a drag car.
[ January 10, 2002: Message edited by: Marty ]
[ January 10, 2002: Message edited by: Marty ]</p>
Old Jan 10, 2002 | 08:41 PM
BIGBOS's Avatar
what gear are you going with in the rear?
Old Jan 10, 2002 | 08:43 PM
Marty's Avatar
<strong>what gear are you going with in the rear?</strong><hr></blockquote>
I have not decided yet. Its probably gonna be a bolt on car for a while. What do yall recomend? I was thinking 4.10.
Old Jan 10, 2002 | 08:47 PM
BIGBOS's Avatar
I'm going with a 3.73 @75 on the highway its around 3200rpms...4.10 on the highway is around 3900.... <img src="gr_eek2.gif" border="0">
4.10 cruising at 45 is 2600, not the best for local driving
Old Jan 10, 2002 | 08:50 PM
Marty's Avatar
<strong>I'm going with a 3.73 @75 on the highway its around 3200rpms...4.10 on the highway is around 3900.... <img src="gr_eek2.gif" border="0">
4.10 cruising at 45 is 2600, not the best for local driving</strong><hr></blockquote>
I know, I know... But I think I'll need that much gear. Hopefully the car won't be on the highway all that much <img src="gr_stretch.gif" border="0">
Marty
Old Jan 10, 2002 | 08:53 PM
BIGBOS's Avatar
You got a trailor <img src="gr_images/icons/wink.gif" border="0">
Old Jan 10, 2002 | 11:04 PM
Marty's Avatar
<strong>I would rather spend the $$ on getting an OD gear than getting a different gear ratio</strong><hr></blockquote>
BTW,
Who sells this OD kit? Is it for 400's only or do they have a 350 version?
