3.42 and 3.73 Gear Questions...
Old 07-18-2005, 12:38 AM
HILL_SS's Avatar
Default 3.42 and 3.73 Gear Questions...
How much do 3.73's on an A4 change the RPM's as far as daily driving, and on gas milage. I have a HPP3 so I will be able to adjust the RMP's and Speedo, but I didnt know exactly how much it affected the drivablilty day to day.
Another question if I was go from the stock 3.23's to 3.42's instead of the 3.73's would I see much of a difference in performace at all?
Old 07-18-2005, 01:50 AM
Ell Ess Won's Avatar
I bought my car already with 3.73....expect to lose on average 2mpg....RPM change- I'm at 3kRPM going 60MPH on the highway in my A4.
Old 07-18-2005, 03:02 AM
Wicked_Hugger99's Avatar
Ur RPMs will go up a noticeable bit but it should not be to bad from going 3.23s to 3.73s. I went from 2.73s to 3.73s in my TA and it wasnt that bad. Never did a MPG check but i was filling up about 50-75miles sooner than before around town(also got F14 cam though) and got about 250-275miles per tank on the highway going to Futral w/ the mods listed in my sig. What Ur MPG is going to be however is tough to say since it all depends on ur driving style but you prolly wont see to much of a difference from 3.23s to 3.73s
3.23 to 3.42 prolly would see a very minimal difference in performance if any at all
Ell ESS WON, 3k@60mph on the highway i was turning about 3k@80mph on the highway w/ my 3.73s
Old 07-18-2005, 11:14 AM
2001NBMZ28's Avatar
A4/3.73/3k Rpm = 88 Mph
Old 07-18-2005, 11:39 AM
LS69TA's Avatar
3K sounds on the high side. I'm turning 2200ish at 70 now with the stock 3.42's.
Old 07-18-2005, 11:53 AM
HILL_SS's Avatar
Aight so its not as bad as I thought then. Do any of you guys have a estimate on time slip difference from 3.23's to the 3.73's.
Old 07-18-2005, 06:02 PM
pla-tym's Avatar
[QUOTE=2001NBMZ28]A4/3.73/3k Rpm = 88 Mph[/QUOTE
60 mph w/ 323's = 1800 rpm
70'''''''''''''''''''''''''''' = 2100 rpm
80'''''''''''''''''''''''''''' = 2400 rpm
60 mph w/ 373's = 2100 rpm
70'''''''''''''''''''''''''''' = 2400 rpm
80'''''''''''''''''''''''''''' = 2800 rpm
Depending on tire size, of course.
Old 07-18-2005, 07:25 PM
ActionJack's Avatar
FWIW
I just swapped my 3.23 out for the 3.73 and I am surprised at the driveableness (is that a word??).
I was hesitant because I did not want to be at too high of an RPM and even though there is a difference it is not bad.
I think a 3.23 to 3.42 might be too small of a difference.
Also, here is a link to help you decide: www.f-body.org/gears
Old 07-18-2005, 09:11 PM
pla-tym's Avatar
.10 maybe....anyone chime in!!
Old 07-19-2005, 07:59 AM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
Try this site, and plug in the numbers:
http://www.f-body.org/gears/
SteveC
Old 07-19-2005, 08:13 AM
SporkLover's Avatar
Yikes, thats twice what Im at, but I have an M6. Double OD rules.
Old 07-19-2005, 04:08 PM
pla-tym's Avatar
He's not @3000 rpm w/ 373's w/ A4. He needs to check it again. No way possible.
Old 07-20-2005, 07:48 PM
NYC FRANK's Avatar
Talking
Im hitting 2,700 rpm at 75 mph . 275/40/17 tire
Old 07-20-2005, 08:31 PM
s346k's Avatar
after swapping in my 373s for 273s i gained .25 i the 1/4 with a best 60' of .12 slower and spinning even more after hitting 2nd. not to mention my best 273 run was on a perfect night and my best 373 run was on a night so humid it looked like it was raining as i accelerated down the track.
