Quick question on footbraking a TP4400
Now, at the track, I can only footbrake it up to like 2200 rpms before I really have to stand on the brakes, I can barely hold the car. I still 60 fted pretty good, I cut a 1.51 and then spun and still cut a 1.53 and a 1.54. Thoughts?
[ January 29, 2002: Message edited by: Trevor D ]</p>
I'd try hammering it from 800 - 1000rpm. That worked when I had a ST3500 since it was a tighter converter. I'd also try from around 2000 rpm.
I'm guessing I could hit a 1.48-1.49 based on my recent 1.51, but I doubt I can do better than that with my current combo.
Using my footbrake comparison of a 346 motor to estimate stall may be more prone to error due to your extra cubes generating more low end torque. your true stall could be higher, but you are limited in your ability to use it w/o a transbrake.
Just curious, how's the mph been running? 120 seems a bit low in the good weather for a big motor.
[ January 29, 2002: Message edited by: Ragtop 99 ]</p>
Went 11.15@120.30mph 1.53 back December, then 11.120.99mph hitting the rev on 1-2 and 2-3.
Since then added a bigger intank.
Went on 1/28/02:
11.25@118.68 / 1.51
11.27@118.76 / 1.55
11.21@119.73 / 1.53
11.20@119.91 / 1.54
Into a headwind, but it should IMO do 123mph at 3600 raceweight into a headwind.
Col shifts at 6800-6900, only difference is he has 600 lbs lighter, has a 112 lsa, more compression. Cams are similar. He also has LS6 heads. He told me to shift at 6600/6600. Right now it's 6100/6200.
I am shooting for 10.75@126mph at 3500 raceweight. I am at 3625 now.
I'm trying to get LS1 Edit since my shift points have never been right on the car in the last couple of years.
