View Poll Results: which rear?
Moser 12bolt
28
25.69%
Moser 9"
81
74.31%
Voters: 109. You may not vote on this poll
question on a 9" or should i go 12 bolt?
im getting close to getting a stronger rear for my car, and now i really have to think of my choices. originally i was thinking 12 bolt but recently im leaning more toward the 9" im most likely going with moser. on a 9" can i retain my ABS (i do not have tcs)? My car is pretty much daily driven, all mods are in sig along with the power i make. I dont plan on doing to much performance stuff for a while besides a 90/90 setup after i finish my drivetrain stuff. The car will see the track, and if i get tired of the power an want more then im definitly gunna be sqweezing. So what you guys/gals think should i stick with a 12 bolt? or should i go with the bulletproof option the 9"? one last thing if i cannot retain my abs that will bring me back towards the 12 bolt, because im trying to maintain the somewhat easy driveabilty factor alive. Thanks guys
-Ryan
-Ryan
you wont be able to keep your abs.... but who needs it
the 9 inch and 12 blot fight has been goin on forever and if your search there is tons of info on each. I just ordered my 9inch and i was in the same boat as you but i fig if i am goin to do it do it right the first time and i wont have to worry about breakin it..... and screw abs who needs it
You know the "12-bolt" has an 8.875" R.G. think about that for a minute.
Now haven't you seen some heavy *** A-body ie.. Chevelle or Buick GS/ GSX with the stock rear take a beating and live? I know I have.
I think with all these complaints the aftermarket housings must be suffering quality control problems.
If your breaking the diff.. well then, maybe you might just have a race car on you hands and you need a spool.
A properly set-up 12-bolt can handle a lot more than you think.
I just installed a Moser 9" from Driveline Solutions in my car and have been very happy with it. My car was already setup for 4 channel so I didn't have to worry about losing my ABS. I wasn't worried about losing a little more power with the 9" over the 12 bolt because I like knowing that I probably won't have to rebuild this 9" rear end for a while. The 9" is stronger than the 12 bolt and that's why I chose it. It seems like most of the problems with Moser 12 bolts is that they are not setup properly by the people at Moser. I believe the parts that Moser uses are good for the most part though. I'd recommend buying a Moser 12 bolt from Driveline Solutions. That way you can keep your ABS, and know that the 12 bolt was setup right.
depends on if you ever want it to break.. a 9" with a locker and 33-35 spline axles.. and you'll never break it no matter what ya throw at it.. most likely atleast.. and i've heard many cases with 12 bolts starting to whine after a few hard launches.. i ehard they are just set up wrong from moser though..
I've heard of 12 bolts breaking more often than 9" rears too.. but the 12 bolt is lighter and you'll be quicker with less weight.. I wish i had a 12 bolt for weight reasons.. but the 9" i never have to worry about!
good luck!
good luck!
We've installed many Moser 12 bolts and haven't had any big problems with them. I have a lot of runs on my Moser 12 bolt and I'm at 540 rwhp on my Mustang Chassis Dyno, which would be 40 to 50rwhp on a Dynojet dyno. I've come out anywhere from 4000 rpm all the way up to 6200 rpm while experimenting with my launches. Bob
Lets just say... U answered it yourself. I know MANY guys run the 9" on the street but its drive-a-bility is far less efficent than the 12bolt. So I'd say go with the 12bolt... Thats what I am going to be doing... Goodluck and let us know what your going to go with!
I got a Moser 9"'s lol 4.10's detroit and 35 spline axles kept both abs/ASR too. I think that was one of the better mods I have done to the car. Too bad I burnt my clutch up on the first and last run that I did in the states w/ that rear end. I still ran a 12.79@110 though compared to my stock set up that gave me 12.9-13.0's quite frequently. I dont think weight should never be an issue compared to durability. One thing for sure about the 9" is that I dont have enough money to even break that thing. I don't doubt 12's are strong but if the gears break in a 12bolt you will have to install new gears under the car or pull the whole rear out. I can just pull the 3rd out and work it on the bench.Which a 9 is easy *** hell to set up. BTW double check your set up from Moser I checked mine out and I needed to tweak some ****. Either way you will be fine. 10 bolts suck well late model 10 bolts do so a 12bolt or a 9 will definatly get you there and back. Oh with the 9 you can make home made spanner wrenches to set the gears cheap too.
damn guys thanks for all the help, im still on the fence on what to do...but ill figure it out...also the only rear company i know of is moser, strange and currie. what are some other ones? what is best? i noticed every1 saying that the moser stuff comes somewhat faulty and takes some tweaking to fix, how big of a problem is that? what is wrong from them? thanks guys/gals
-Ryan
-Ryan
-Ryan
-Ryan
markwilliams.com
I've run my Moser 12 bolt 33 spline TrueTrac with 3.73's 30 some odd times this year and haven't noticed ANY increased gear noise or any gear noise for that matter. Sticky tires with a full bolt on car and a cam launching at 5500-6500 RPM. If there were going to be any problems at my level they would have surfaced by now.
-Ryan
-Ryan
