Which gears with a PT4400?
Old Feb 5, 2002 | 08:10 PM
Form4speed's Avatar
Default Which gears with a PT4400?
I will be adding a Yank PT4400 to my car in the coming weeks and I am still confused about which gear would be best in the rear end? Currently the car has the stock 2.73s in the rear, and I am sure they would not work well with a PT4400. Streetability is not a concern because the car rarely sees heavy traffic. I am mainly focused on Drag strip performance. From what I have read 3.42s and even 3.73s are recommend as a good street/strip combo. However, would I see any performance gain with a 4.10? I have been told with a 4.10 I could run a 28in tire, and that seemly would give me better traction. Would a 4.10 be a good gear for a moderately street driven vechile? These gears will go into the stock 10 bolt and I will be running slicks on the track.
Also which suspension mods would help me the most? I will be putting some BMR subframe connectors on. What else would help give me better traction?
Thanks for the help!
Old Feb 5, 2002 | 08:50 PM
Patrick G's Avatar
LS1 Tech Administrator
Default Re: Which gears with a PT4400?
On a mild Head/Cam motor, I've only seen .05-.10 in ET gain by going from a 3.23 gear to a 3.73 with the Pro Thruster 4400...it's that good. If you do mainly street racing (i'm talking street racing from a dead stop), then 3.23 gears would be perfect. If you only race from a roll like the ricers do, then 3.73 gears would be best.
For the track, 4.10 gears with a tall tire would be the ultimate, but you better have a motor that can pull over 6500 rpms to fully use it.
You could even keep your 2.73 gears although they would make this loose converter feel very LOOSE!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 5, 2002 | 09:19 PM
Form4speed's Avatar
I do my races from a stop, like a man <img src="gr_images/icons/wink.gif" border="0">
So you are saying 3.23s would be the best from a stop?
Old Feb 6, 2002 | 09:28 AM
WILWAXU's Avatar
If your primarily thinking of street racing with a TP-4400 with any gear.. better look at some ET streets or look at a different converter.
If your looking for the best(quickest) track combo, 3.73 with TP-4400 offers great drivability and is a terror at the track.
Old Feb 6, 2002 | 10:42 AM
Form4speed's Avatar
I rarely street race, so that is of no concern. Track use is my biggest concern.
I have gotten two different suggestions here on which gear to get. Any one have a reason why one or the other gear offers a better combo with the PT4400?
Thanks for all the info so far, this is a big help!
Old Feb 6, 2002 | 11:18 AM
CHRISPY's Avatar
I run the TP4400 converter and 4.11 gears with spool at the track and it is a beast <img src="gr_stretch.gif" border="0">
Cheers,
Chris
Old Feb 6, 2002 | 11:25 AM
Terry Burger's Avatar
4.10s are a good gear if you have tire. <img src="gr_images/icons/wink.gif" border="0">
Old Feb 6, 2002 | 11:34 AM
Skelton's Avatar
I run the tp4400 and 4.10 gears with stock internals. It is a killer strip setup with 28 inch tires but I firmly believe 3.73's with 26 inch tires is the ultimate for stock internals. I have 60ft'd the best of 1.50 but I hit 6500 rpms at the finish line with 26ers which is about 1k rpms past my peak hp and is just plain too tight. I'm keeping the 4.10's since I will now be running heads/cam/nitrous and 29 inch tires but if I were staying stock internals, I'd switch to
3.73's. I agree though that the difference between 3.23/3.42 to 3.73 may just be .05-.1 at the most in et reduction. The converter is damn good.
Old Feb 6, 2002 | 04:49 PM
Form4speed's Avatar
Right now it looks like my gear of choice will be the 3.73s. From what I read they offer a good strip set up, and also will tighten up this loose tranny for around the town driving. I think 26in tires will be enough for a bolt on car, heads and cam in the future. Again thanks for all the help.
