pic inside: clearance problem with phr on eibach prokit
l=lower
u=upper
i was under the car and notice that the passenger side mount where the uphr and lphr are bolted that when the car is sitting normal the to phr's are pushed against each other.. this only gets worse as the suspension comresses..
any thoughts? a tubular lphr will help this i believe.. i have a few shots of it.
this causing a slighty bumpy condition on the right rear?
I've got the BMR adj. PHR and Prokit and don't have any problems where they meet on the passenger side but the Uphr does cup over the BMR PHR slightly. Since it's tubular, it kinda just fits right into the upside down "U" shape of the Uphr.
I can see how the stock ones would crunch together there. You can solve it for about $100. Get the dual adj PHR. Piece of cake to install and set.
Andy <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
[ March 08, 2002: Message edited by: WEASEL ]</p>
The bumpy ride is all from your Eibach Pro Kit.
Get subframe connectors and some good shocks if you're still using the factory DeCarbons, and your ride will smooth out quite nicely.
<strong>what is the going rate for one of those do-dads? (red) I still have my x-mas coupon if that makes a difference <img src="gr_images/icons/wink.gif" border="0"> </strong><hr></blockquote>
Well the X-mas card discount expired back in January but the BMR adjustable PHR is $109. Maybe I can throw in shipping or something. <img src="gr_stretch.gif" border="0">
Paul
