Rear End Girdle?
Old Dec 26, 2005 | 10:34 PM
CadillacEXTon27's Avatar
Default Rear End Girdle?
Hello,
I was wondering if anyone has a MAC REAR END GIRDLE or any info on this brand of REAR END COVERS? I was thinking of getting one but not sure of this BRAND. Any HELP would be GREATFULL..
Thanks
Chris M.
Old Dec 27, 2005 | 07:00 AM
EPP's Avatar
EPP
The rear end covers are most likely made by one or two companies. The Mac looks to be a good piece, we carry it on our website. Bob
Old Dec 27, 2005 | 07:26 PM
dailydriver's Avatar
^^^^^^ what he said. I have the Mac cover, which was put on when I installed the 4.10s. I feel it may have helped save my 10 bolt for 80K+ very hard miles with an M6 (that, setup and regular gear oil changes). I would go with either the Mac or a TA, although others are very similar.
Old Dec 27, 2005 | 09:22 PM
Thanks.
for the FEEDBACK?
Old Dec 27, 2005 | 11:01 PM
Anyone else using the MAC REAR END GIRDLE?
Old Dec 28, 2005 | 11:54 AM
jimmyblue's Avatar
Moderator
I have one. It seems like a stout piece. I was not all that
impressed by some of the casting / machining details (just
seemed a little roughly worked in spots, esp. the threaded
holes) but it doesn't leak, fitted up fine and so on. I had to
leave off all of the lock washers because the Allen head
bolts were too short to draw in, with them in there.
Basically it's an aluminum pot and about as good as any other
aluminum pot, and better than some (drain plug, preload studs).
Old Dec 31, 2005 | 11:11 PM
35th SS's Avatar
been using since I switch to 3.73 good piece my 10bolt still holding up from every weekend abuse at the track plus n2o out of the hole launch.
Old Jan 1, 2006 | 08:51 PM
Mike2000Z28's Avatar
if you get one, go to a hardware to get better, longer bolts, then the one in the kits. Other then that I was really happy with mine.
Old Jan 1, 2006 | 09:49 PM
RaNsOm's Avatar
I ran my girdle on the 10bolt and when I took the rear out to put the 12bolt in, it was just as quiet as the day I bought it.
