what could be rong?
after i installed my new 10 bolt ive been getting this vib comeing from the back of the car. and with the mount it got worse which makes me think its my drive shaft. i got my wheels ballenced and it didnt help, what else could i look into that might be causing this...... i can feel it through the center consull and in the seat and it only does it 50mph and above.
please help me!
ryan
does anyone know how much motormount install will run me? i might put em on my self if the price is too high.
As for the poly tranny mount, if you used the preload plate, don't. Those will definitely cause more vibrations.
My suggestion. Grind the preload bumps off the tranny mount & don't not use the spacers plate. That should get rid of most of the vibration.
what i was gonna say
to me it feels like something is out of ballence. anywhere below 50-55 its as smooth as can be, but once i get to 50 and up and not too smooth anymore.
about the preload bumps.... what exactly ate you talking about? if someone could get me some pictures it would really help. do all poly mounts have preload bumps?
thanks for tha help, ryan
as for maybe haveing a bent axle..... what would be the best way to diagnose this problem? i talked to the guy and he said he no problem with viberations in his car with it in, the rearend only has 40k miles give or take a little.
thanks, ryan
but still at 55 mph a viberation starts and its almost unbarable, how can i diagnose this problem.
i was thinking about the pinion angle but with a stock rearend and stock tq arm it doesnt seem like the pinion angle would be off. what do you guys think about this?
1st the driveshaft is either bet or out of ballence, i replaced it with one from my friends wrecked 99 t/a and no more bad viberations!
2ed did they put aluminum DS's in 98 ls1 cars? mine didnt have a aluminum drive shaft and my friends 99 did (which is now in mine)
