how to beef up a 10 bolt???
Right now im running on some 295's kumhos in the rear and I have around 350rwhp...im not gona get much higher than this so thats why im not gona upgrade the whole rearend.
https://ls1tech.com/forums/showthrea...t=beef+10-bolt
realistic answers) about how you expect to drive / beat on
the car, whether you are going to change gears or converter
(if A4) or tires and so on.
A 2.73 car would probably never need axles. A 4.10 car with
a high STR converter and slicks would probably twist off any
10-bolt axle, even aftermarket, eventually if the rest of the
guts were up to it. There are plenty of things you could
upgrade but which, or whether, "depends".
My best 60' is in my sig with drag radials and a bone stock 10 bolt. Now, finally after about 200 passes at the track the posi has finally started to give a little trouble (won't lock correctly anymore under heavy load).. so I bought a used Eaton posi for cheap off Ebay to try.
I did axles, a girdle, and a new posi unit and it went Boom my second time out on Nittos with 345RWHP and 356RWTQ
On my second 10 bolt with a girdle and launching very soft and so far it has held but it gets louder everyday in the summer!!!Dan
i feel the same way, my motor is stock, and will be for a few more years. my mods in sig. Looking to get all boltons, 3.73s and maybe 100wet shot next year . Im not going to do 5k and dump launches and Its not my daily driver. i figure whenever i do the 3.73s, ill beef it up while everything's out. itll never see slicks, maybe drag radials, but thats about it.
I was launching at 2500 to 3000rpm and Like I said on Nittos, and mine is no where near a daily driver maybe 2 times a week at most and only 6 mos out of the year.
Dan
