Torque arm bracket for 9in????
Old Jan 3, 2006 | 07:37 AM
Z'mnypit's Avatar
Default Torque arm bracket for 9in????
Does anyone know if I need the torque arm bracket for a 9in if I dont plan on using the stock torque arm? What Im saying is the bracket that is required for the 10 bolt arm to work on the 9in isnt there all that is on the rear is 2 cylinders where the mount would go. If I didnt plan on using the stock torque arm, would I still need this bracket? Or is there a torque arm that bolts directly to the 9in? Sorry if this doesnt make sense.
Old Jan 3, 2006 | 08:50 AM
LoPeY's Avatar
You would need to keep that TA mount even with an aftermarket TA. Without some custom fabbing, there would be no place to mount the torque arm to the rear.
Old Jan 3, 2006 | 09:00 AM
Z'mnypit's Avatar
Damn, thats what I was afraid of. Does anyone know where I can get one? Ive called moser & they dont sell them seperatly. I bought this used, so I dont even have the old one.
Old Jan 3, 2006 | 09:27 AM
LoPeY's Avatar
I'd call some of the sponsors that carry Moser, they can probably pull some strings for you.
Old Jan 3, 2006 | 09:52 AM
Z'mnypit's Avatar
Ill give it a shot! Thanks!
Old Jan 4, 2006 | 02:39 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
2 cylinders? the bracket mounts with 3 not 2 maybe the other one broke off????good luck with getting the bracket. oh do you have a pic of the rear. if you want i can post a pic of mine so can see what i mean
Old Jan 4, 2006 | 05:21 PM
here's a post with pics of the 9" installed if you look at post #11 you can see the different pics of the ta mount.
https://ls1tech.com/forums/showthrea...veshaft+length
Old Jan 5, 2006 | 07:44 AM
mondi2002's Avatar
I found this looking for Complete Rear. Very Interesting.
Never heard of this being an option. (Bolt on Torq arm bracket)
http://www.currieenterprises.com/CES...6.aspx?id=1595
Old Jan 5, 2006 | 09:00 AM
Demon_Speeding's Avatar
From what I can see in that pic it looks pretty close to what's on my Moser.
Old Jan 5, 2006 | 09:21 AM
BigKap94z's Avatar
AutoWeld chassis also sells a Torque arm mount for the Ford 9". It is the same price as the Currie enterprises one, but is a different design. It also makes your stock torque arm fully adjustable...so that is an advantage as well. Here is the link to the page its shown on, http://autoweldchassis.com/vbi.ivnu. It is a ways down under the camaro section.
Old Jan 5, 2006 | 01:49 PM
LoPeY's Avatar
That's my rear end!
Old Jan 5, 2006 | 02:46 PM
Z'mnypit's Avatar
Thanks guys, Ill try to get pics either today or tommorow.
Old Jan 5, 2006 | 04:03 PM
Z'mnypit's Avatar
It has 3 cylinders my bad, im not sure why I said 2.
Old Oct 13, 2007 | 11:37 PM
Bersaglieri's Avatar
I might be in the same boat, did you end up finding somewhere that has one?
-Dustin-
